cucm sub pblm link
renji joy
Dear all
Iin cucm subscriber intsllation is finish/ after installation .unfortunatily need to change the ip address sub after changing ip
using this command show network etho
link detected is stage is no
not able communicate other systems even gateway
15 Replies 15
If it is only a SUB , why don't you re-install it from scratch, it is easier and it is only have to be configured on the CUCM as a new server with the new IP address.
Amer
Hi amer,
Only one pub and sub pblm found in sub (any pblm reinstall the sub server) after the change th ip address
thanks
getting this one
Show Network eth0=
dhcp: disabled
status: up
ip add 172.16.11.28
ip mask 255.255.255.252
link detected: no
mode: auto enable, unknown! (255), N/A
This is older post i am also facing this same issue
Currently Being Moderated
Connecting TO Call manager
I have it direct connected to a 2924 switch, the NIC and switchport show green. The switch is going to a 2800 router. I
I assigned the MCS 172.16.11.28, but no matter what IP I use I can't ping it or log into it.
Tested all the cables.
Show Network eth0=
dhcp: disabled
status: up
ip add 172.16.11.28
link detected: no
DNS
Primary 172.16.11.28
secondary:
options timeout:5 attmepts:2
domaing:ipswitch
gateway:xxxxxxxx
server booting time getting one error message
Bringing network eth0 this time
device not found xxxxx
like this
Hi all
I've tried to force a setting, but I can't get anything to work. Set Network nic eth0
Then variations of auto disable, full, 100, etc..
It ALWAYS kicks back "command executed unsuccessfully
Pls give me one solution
Latest status is find below
admin:show network eth0
Ethernet 0
DHCP         : disabled           Status     : up
IP Address   : 192.168.35.50      IP Mask    : 255.255.255.000
Link Detected: No                  Mode       : Auto enabled, Half, 100 Mbits/s
Duplicate IP : no
only pblm is Link Detected: No  not able communicate with gateway and other systems
It looks like you're running at half duplex:
Check your switch settings to make sure it's set to auto and/or hard code it to full duplex.
HTH,
Chris
Hello
        Chris
I have already check this one but no chance still showing link detected is No
now i am connected cable to NIC port 2 is working fine,any idea what is the pblm for
NIC 1
It could be a hardware defect , you are saying that when you convert to NIC2 , all is working fine , i don't think you changed something from the switch or anything , you just plugged the cable right , so my guess is that the NIC1 has a hardware defect.
Amer
Yes i  just plugged the cable NIC2,
so it is a hardware defect , if you have a active support contract replace the box , but there is no problem with working on NIC2.
Amer
How to replace pls send me the procedure
Open either a RMA case or cisco TAC case , the engineer will check the problem and then he will order a RMA replacement for your hardware , depends on your support level you will recieve the replacement.
Amer
