CUCM to IPphone 7841 SIP over UDP ?
NBRK_Cisco
Hello ALL,
please advice me
is it possible to make transport protocol SIP over UDP between CUCM 11.5 and IP Phone 7841 ?
2 Accepted Solutions
You ALWAYS have to configure the SIP profile and phone security profile for devices, they are MANDATORY fields. And those are two different settings in the device page.
Assign the phone security profile with UDP only to the phone you want.
java
if this helps, please rate
Here you go..
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Ratheesh Kumar
Hi there
Please check this post. I hope you find the answer.
https://supportforums.cisco.com/t5/ip-telephony/cisco-7821-sip-over-tcp-only/td-p/2711507
Hope this Helps
Cheers
Rath!
Thanks a lot.
but I can not see how the non-secure profile is connected to the phone?
when configuring phone there are only standart sip profile.
I mean I want to change configuration of only one phone. not all of them.
java
Here you go..
Hope this Helps
Cheers
Rath!
