CUCM Upgrade 6.0 to 6.1 to 8.6
Abbas Ravat
Dear All
I want to upgrade CUCM 6.0.1.3000-7 [ 6.0(1b)] to CUCM ver 8.6.  now there is no direct upgrade to 8,6 from version 6.0.
Upgrade path is 6.0.1.3000-7  to 6.1.1.3000-2
6.1.1.3000-2 to  6.1.3.3000-1
6.1.3.3000-1 to  6.1.4.2190-3
and then 6.1.4.2190-3 to 8.6
Now I am about to upgrade first stage that is 6.0.1.3000-7 to 6.1.1.3000-2.
Kindly please can you help me step by step on how can I carry this 1st stage of upgrade.
your immediate reply is highly appericated.
Thanks you.
6 Replies 6
Gajanan Pande
Abbas,
Release notes guide of the destination version would have the detailed upgrade procedure. For your 6.1.1, here you go http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_1/cucm-rel_note-611b.html#wp322228
GP.
Pls rate the post if it helps !!
There are also hardware considerations here.  Are you doing the upgrade on existing 6.x servers or using new hardware to get to 8.6?
Hailey
HI David
Thanks for the reply.
I am doing upgrade on existing hardware. Can you please advice how i can upgrade from version 6.0.1.3000-7 to 6.1.1.3000-2 that is 6.0(1b) to 6.1(1b).
Dear Gajana
Thanks for reply,
Attached document for Upgrade to 6.1(1b) says this upgrade from 6.0(1) or 6.0(1a).
What i have is version 6.0(1b) as my current version and from this version I want to upgrade to 6.1(1b). Document you send does not mention upgrade from 6.0(1b).
Kindly Advice.
Hi Abbas,
Please refer the table "Supported upgrade paths to/from table" in the below link for your current upgrade plan,
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
For step by step procedure for specific version CUCM upgrade, refer the release notes of that version,
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/prod_release_notes_list.html
Also verify if your current hardware supports the upgradable version from the below link,
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps.
Anand
pls rate helpful posts !!
Abbas,
Regardless of CUCM versions ( in minor upgrades ), the procedure remains same. Your case also is of minor upgrade hence procedure remains same only the upgrade file name will be changed. You will use the upgrade file downloaded from CCO & use the same upgrade procedure.
GP.
