CUCM upgrade from 7.1.5bSU3 to 8.5.1
kbeelwar
I have MCS servers as follows:
I have UCS C210 servers where I have installed VMware ESXi and want to use this vmware 8.5.1 as new cucm.
The issue is I see my current hardware on MCS does not support upgrade due to memory/HDD requirement. I am suggested to temporarily use mcs to upgrade to 8.5 and take backup.Install vmware 8.5.1 and restore. This approach sounds ok except I am worried my install may not work making my mcs cucm production enviroment go down.
Has anyone got better recommendation? Do you think the above method will work?I just have 15 hours of downtime where i need to get the servers up.
Pls help!!
Kads
Product
Current   Hardware
Memory/Disk
Supported
Recommendations
US   CM-osi-cm10
MCS7825H3-K9-CMB1
Platform     Type
7825H3
Memory: 2048 MB
Disk Size: 152587 MB
Yes
Upgrade   to 4 GB Memory is strongly recommended.
Disk Size is ok, no upgrade   is necessary
US   CM-osi-cm11
MCS-7825-H2-IPC1
Platform     Type
7825H2
Memory: 2048 MB
Disk Size: 76293 MB
Yes
Upgrade   to 160GB Disk Size is strongly recommended
US   CM-osi-cm12
MCS-7825-H2-IPC1
Platform     Type
7825H2
Memory: 2048 MB
Disk Size: 76293 MB
Yes
Upgrade   to 160GB Disk Size is strongly recommended.
APAC   CM-osi-cm20
MCS-7825-I4
Platform     Type
7825I4
Memory: 2048 MB
Disk Size: 238GB
APAC   CM-osi-cm21
7825H2
Platform Type 7825H2
Memory: 2 GB
Disk Size: 80 GB
EMEA   CM-osi-cm30
7825H2
Memory: 2 GB
Disk Size: 160 GB
EMEA   CM-osi-cm31
7825I
Memory: 2 GB
Disk Size: 80 GB
If you've got three separate clusters, 15 hours per cluster should be plenty of time.
I've not run a live cluster entirely under VMWare - but CUCM is supported under VMWare (with various caveats)
All I would say, is that you're not going to want to run all the nodes of a cluster on the same VMWare box (unless you *really* understand the pros and cons of this - e.g. no more hardware resliancy)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/virtual/servers.html
and
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
are probably good places to browse.
GTG
Please rate all helpful posts.
Gordon Ross
Level 9
Level 9
I'm slightly confused with what you're wanting to do. Are you saying you want to migrate all seven servers to CUCM 8.5 - all running under VMWare ? (I hope you don't want to run all seven CUCM instances on the same VMWare box...)
Or that you want to use VMWare as a staging area to allow you to install CUCM 8.5 on your MCS servers ? (In which case, I can't see the point of this. Why not just upgrade the RAM/HDs & do a normal upgrade ?)
On a slightly related note: 15 hours to do a straight software upgrade on 7-node CUCM cluster is doable. Memory upgrade should be trivial, in terms of time. Replacing the HDs will add considerably to the time element. Without knowing more details of your cluster setup, it's hard to say whether you could do it or not. (e.g. Are your backup subscribers actively used for things ?)
Hello Gordon,
1. There are 3 seperate clusters comprising of 3,2,2 servers in every region.
2. MCS servers do not have memory nor HDD capacity so I was hoping to migrate from mcs to  vmware servers with plans as such for every region
UCS1 : UCCX 8.5
            CUCM 8.5 Publisher
UCS2 : CUCM 8.5 Subscriber
3. I have 15 hours of downtime for every cluster to migrate from mcs to vmware which I believe is very doable, just wanted a confirmation if my planning is ok.
4. Have you seen any issues with running whole cluster on vmware?
Hope this answers your queries and thank you for helping me with this.
Kads
and
GTG
bvanturn
For this you can do a bridge upgrade. This will allow you to perform the upgrade. However once upgraded, the software will only allow you to take a backup which you can then use for a restore on your UCS platform.
More info on bridge upgrades in the Operating System Administration Guide.
