10-13-2020 05:10 AM
Dears,
I have cucm 12.0 and two devices registered automatically to enhanced plus license but i dont purchase any enhanced plus license
this problem caused to stop any edit or add new device or any thing on cucm
is their any solution instead of repurchase enhanced plus license
** if i apply this command from cli "license management reset registration" it will solve problem with out reset all extension and the registed phones
10-13-2020 05:22 AM
You have two user who use two devices each. That’s the reason it took enhanced plus.you can check the users who consume enhanced plus from the same page.
it should borrow from the upper tier.
10-13-2020 06:27 AM
Yes, This is the problem and look for solution for it
10-13-2020 07:03 AM
10-13-2020 07:12 AM
Dear,
I have free enhanced but i cant edit or apply any changes in cucm because " out of compliance " problem
10-13-2020 10:20 AM
So the grace period to resolve the licensing issues has been over ??
you can contact local Cisco SE to support.
10-13-2020 10:26 AM
What is the reason for that you waited for the grace period of 90 days to pass before you asked for help on this? Right now you would need to add licenses to get to the good side of compliance again before you can do any changes in CM.
