CUCM - what does DRS will not backup
If we look at the documentation of DRS we can see what DRS can backup, but its.. not clear.
I mean, what doest it need to be manually configure after a DRS Resotre ?  ...Enterprise parameters ?  All the option under System ?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/8_0_1/drsag801.html
What DRS Backuo =
• Cisco Unified Communications Manager database (CCMDB), includes Cisco Unified Communications Manager/CDR Analysis and Reporting/Call Detail Records)
• Platform
• Music On Hold (MOH) Audio Files
• BAT Bulk Provisioning Service (BPS)
• CCM Preference Files (CCMPREFS)
• TFTP Phone device files (TFTP)
• SNMP Syslog Component (SYSLOGAGT SNMP)
• SNMP CDP Subagent (CDPAGT SNMP)
• Trace Collection Tool (TCT)
• Cluster Manager (CLM)
• Cisco Extended Functions (CEF)
5 Replies 5
Gordon Ross
Level 9
Level 9
DRS backs up everything (Except the DRS configuration)
When I've restored my pub from a DRS backup, I had to do nothing to else to the box to get the cluster back to the state it was in before. (well, except for rebooting the subs)
GTG
Please rate all helpful posts.
DRS should include everything - and it does mostly.
The exception I've seen is that when restoring to a new/reinstalled server, the restore usually works but subsequent upgrades often fail unless you reinstall any locale files.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I had an issue where DRS did't backup the :
-Auto registration configuratiion  ( for phones )  in System / CM configuraton  and CM group
-backgroud of IP phones
-RTMT settings
But, what else I am asking me...
-RTMT settings
I have seen bugs where DRS has missed things. (On one occasion it missed all the certs) But DRS should be backing these things up. It certainly does for me. If you think it's missing something, log a TAC case.
GTG
anchoudh
Level 9
Level 9
Hi Philippe,
Adding to the above list.
Note
After  you regenerate certificates in Cisco Unified Communications Operating  System, you must perform a backup so that the latest backup contains the  regenerated certificates. If your backup does not contain the  regenerated certificates and you must perform restoration tasks for any  reason, you must manually unlock each phone in your system so that the  phone can register with Cisco Unified Communications Manager
Hope this helps.
Anand
