debug isdn q931 -
Hello Community,
I would like your feedback on the following:
We have replace an old PBX with a Cisco Communications Call Manager 8.6 with an MGCP voice-gateway connected with a PRI line.
When enabling the debug isdn q931 on the router we observe that on outgoing calls we notice the calling and called party but on the incoming calls we see only the called party:
Outgoing calls
VG#
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838E
                Exclusive, Channel 14
        Calling Party Number i = 0x0081, '9530'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '01895XXXXXX'
Dec 11 11:40:00.155: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8090
Dec 11 11:40:00.799: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8090
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Dec 11 11:40:00.823: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8090
Dec 11 11:40:00.823: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x009
Incoming calls
Dec 11 11:38:28.011: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
        Channel ID i = 0xA98381
        Progress Ind i = 0x8483 - Origination address is non-ISDN
       Called Party Number i = 0x81, '215562'
                Plan:ISDN, Type:Unknown
        Low Layer Compat i = 0x9090A3
Dec 11 11:38:28.023: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8001
Dec 11 11:38:28.027: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8001
Dec 11 11:38:39.435: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8002
        Cause i = 0x8090 - Normal call clearing
I just want to confirm that there is no configuration missing and may only need to speak with the provider, however, i was informed that the incoming callerID was operational on the old system.
Any help is really appreciated!
George
paolo bevilacqua
Telco is not sending calling number. Sometime they charge for that.
5 Replies 5
Are you sure the service provider is sending you the callerID? Some service provider charge you a additional fee for this service, so maybe is disabled. The PRI T1 by default will allow callerID information to be received...
_____________________________
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Yes it was working on the old PBX, which was not Cisco.
Try this command: debug voip ccapi inout. Please send us the result.
Can the below be useful to you?
Dec 11 13:04:48.890: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x318F621C, Interface Type=6, Destination=, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D00000000101ab7b000000F5000000af)
Dec 11 13:04:48.890: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Dec 11 13:04:48.890: :cc_get_feature_vsa malloc success
Dec 11 13:04:48.890:  cc_get_feature_vsa count is 3
Dec 11 13:04:48.890: :FEATURE_VSA attributes are: feature_name:0,feature_time:730976544,feature_id:13290
Dec 11 13:04:48.890: //13290/2D82BE9F99F7/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Dec 11 13:04:48.890: //13290/2D82BE9F99F7/CCAPI/ccCallSetContext:
   Context=0x30E25A88
   Interface=0x3151C6C0, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
Dec 11 13:04:48.890:  cc_get_feature_vsa count is 4
Dec 11 13:04:48.890: :FEATURE_VSA attributes are: feature_name:0,feature_time:730976992,feature_id:13291
Dec 11 13:04:48.890: //13291/2D82BE9F99F7/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Dec 11 13:04:48.890: //13291/2D82BE9F99F7/CCAPI/ccCallSetContext:
   Context=0x30E24D78
Dec 11 13:04:48.890: //13291/2D82BE9F99F7/CCAPI/cc_api_call_connected:
   Interface=0x3151C6C0, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Dec 11 13:04:48.890: //13290/2D82BE9F99F7/CCAPI/cc_api_call_proceeding:
   Interface=0x318F621C, Progress Indication=NULL(0)
Dec 11 13:04:48.890: //13290/2D82BE9F99F7/CCAPI/cc_api_call_connected:
   Interface=0x318F621C, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
Dec 11 13:04:48.890: //13290/2D82BE9F99F7/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x31AE7DE8, Call Id=13290
Dec 11 13:04:48.890: //13290/2D82BE9F99F7/CCAPI/ccCallReportDigits:
   (callID=0x33EA, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=13290
Dec 11 13:04:48.890: //13290/2D82BE9F99F7/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x318F621C, callID=0x33EA, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x318F621C, Call Id=13290
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Dec 11 13:04:48.890: //13290/2D82BE9F99F7/CCAPI/ccConferenceCreate:
   (confID=0x31AE800C, callID1=0x33EA, gcid=0-0-0-0, tag=0x0)
Dec 11 13:04:48.890: //13291/2D82BE9F99F7/CCAPI/ccConferenceCreate:
   (confID=0x31AE800C, callID2=0x33EB, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x31AE800C, Call Id1=13290, Call Id2=13291, Tag=0x0
Dec 11 13:04:48.890: //13290/2D82BE9F99F7/CCAPI/cc_api_bridge_done:
   Conference Id=0x19F5, Source Interface=0x318F621C, Source Call Id=13290,
   Destination Call Id=13291, Disposition=0x0, Tag=0xFFFFFFFF
Dec 11 13:04:48.894: //13291/2D82BE9F99F7/CCAPI/cc_api_bridge_done:
   Conference Id=0x19F5, Source Interface=0x3151C6C0, Source Call Id=13291,
   Destination Call Id=13290, Disposition=0x0, Tag=0x0
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/cc_generic_bridge_done:
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x19F5, Destination Call Id=13291)
Dec 11 13:04:48.894: //13291/2D82BE9F99F7/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x19F5, Destination Call Id=13290)
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3151C6C0, Destination Call Id=13291, Source Call Id=13290,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Dec 11 13:04:48.894: //13291/2D82BE9F99F7/CCAPI/cc_api_caps_ind:
   Destination Interface=0x318F621C, Destination Call Id=13290, Source Call Id=13291,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Dec 11 13:04:48.894: //13291/2D82BE9F99F7/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3956)
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/cc_api_caps_ack:
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x318F621C, Call Id=13290
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/cc_api_voice_mode_event:
   Call Id=13290
   Call Entry(Context=0x30E25A88)
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x19F5, Call Id1=13290, Call Id2=13291
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=13290
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/ccCallReportDigits:
Dec 11 13:04:48.894: //13290/2D82BE9F99F7/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
Dec 11 13:04:49.162: //13290/2D82BE9F99F7/CCAPI/ccCallModifyExtended:
   Nominator=0x31AE7D08, Params=0x31AE6E90, Call Id=13290
Dec 11 13:04:49.162: //13291/2D82BE9F99F7/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x31AE70A0, Call Id=13291
Dec 11 13:04:49.162: //13290/2D82BE9F99F7/CCAPI/cc_api_call_modify_done:
Dec 11 13:04:49.162: //13291/2D82BE9F99F7/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x3151C6C0, Call Id=13291
Dec 11 13:04:52.894: //13290/2D82BE9F99F7/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
Dec 11 13:04:58.098: //13288/20EF246F99F6/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=13288
Dec 11 13:04:58.098: //13288/20EF246F99F6/CCAPI/ccCallModifyExtended:
   Nominator=0x31AE7D08, Params=0x31AE6E90, Call Id=13288
Dec 11 13:04:58.098: //13289/20EF246F99F6/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x31AE70A0, Call Id=13289
Dec 11 13:04:58.098: //13288/20EF246F99F6/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x318F621C, Call Id=13288
Dec 11 13:04:58.098: //13289/20EF246F99F6/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x3151C6C0, Call Id=13289
LondonVG#
LondonVG#
Dec 11 13:05:01.206: //13288/20EF246F99F6/CCAPI/ccCallModifyExtended:
Dec 11 13:05:01.206: //13289/20EF246F99F6/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x31AE70A0, Call Id=13289
Dec 11 13:05:01.206: //13288/20EF246F99F6/CCAPI/cc_api_call_modify_done:
Dec 11 13:05:01.206: //13289/20EF246F99F6/CCAPI/cc_api_call_modify_done:
Dec 11 13:05:01.210: //13288/20EF246F99F6/CCAPI/ccCallReportDigits:
   (callID=0x33E8, digit_event=0x0, enable=FALSE, consume=FALSE)
   Enabled=TRUE, Call Id=13288
Dec 11 13:05:01.210: //13288/20EF246F99F6/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x318F621C, callID=0x33E8, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x318F621C, Call Id=13288
Dec 11 13:05:01.210: //13289/20EF246F99F6/CCAPI/ccGetCallStatistics:
   Call Stats=0x30E562B0, Call Id=13289
Dec 11 13:05:01.210: //13288/20EF246F99F6/CCAPI/ccConferenceDestroy:
   Conference Id=0x19F4, Tag=0x0
Dec 11 13:05:01.210: //13288/20EF246F99F6/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x19F4, Source Interface=0x318F621C, Source Call Id=13288,
   Destination Call Id=13289, Disposition=0x0, Tag=0x0
Dec 11 13:05:01.210: //13289/20EF246F99F6/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x19F4, Source Interface=0x3151C6C0, Source Call Id=13289,
   Destination Call Id=13288, Disposition=0x0, Tag=0x0
Dec 11 13:05:01.210: //13288/20EF246F99F6/CCAPI/cc_generic_bridge_done:
Dec 11 13:05:01.210: //13288/20EF246F99F6/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Dec 11 13:05:01.210: //13288/20EF246F99F6/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Dec 11 13:05:01.210: //13289/20EF246F99F6/CCAPI/ccCallDisconnect:
Dec 11 13:05:01.222: //13289/20EF246F99F6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3151C6C0, Tag=0x0, Call Id=13289,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Dec 11 13:05:01.222: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Dec 11 13:05:01.222: :cc_free_feature_vsa freeing 2B91D658
Dec 11 13:05:01.222:  vsacount in free is 3
Dec 11 13:05:01.230: //13288/20EF246F99F6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x318F621C, Tag=0x0, Call Id=13288,
Dec 11 13:05:01.230: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Dec 11 13:05:01.230: :cc_free_feature_vsa freeing 2B91CD98
thanks,
george
paolo bevilacqua
