Deleting Mediasense node from Primary
antonio.vazquez
we have tried to add a new MediaSense node to the cluster (right now we only have primary node), but IP Address is incorrect. We want do delete secondary node and the only way that we have found is explained in the following link
http://docwiki.cisco.com/wiki/Installation:_Incorrectly_Configured_last_MediaSense_node_on_Primary_for_MediaSense_10.5(1)_SU1_and_above
Is there any risk? Is enough if we run the following SQL sentence over the primary node?
run sql DELETE FROM ProcessNode WHERE NodeId="2"
Or shall we run the following too?
run ora_sql config "DELETE FROM Properties WHERE NodeId=2"
We are running Mediasense 10.5.1.12001-136
haider.rizwan
Have you tried above to remove node from Primary?
Is that works fine without any issue?
