07-05-2020 02:43 AM - edited 07-05-2020 02:44 AM
im configuring a H323 E1 voice gateway but whenever i input this command "network-clock select 1 controller E1 0/1/0" i get this message
"G.781 based clock selection process is enabled Please unconfigure G.781 based configuration before configuring network-clock select config"
and i cant figure out how to unconfigure it?
also is this command correct with regard to the slot , port adapter and port number
configure network-clock select 1 controller E1 0/1/0
this is "show inv"
NAME: "NIM subslot 0/1", DESCR: "NIM-1MFT-T1/E1 - T1/E1 Serial Module"
PID: NIM-1MFT-T1/E1 , VID: V05
07-05-2020 05:41 AM
07-05-2020 12:18 PM
please can any expert suggest any solution?
07-06-2020 04:00 AM
Please post your running config so that we can see what you have configured.
07-06-2020 04:16 AM
use the below configuration.
controller E1 0/1/0
framing no-crc4
clock source line primary
pri-group timeslots 1-20
network-clock synchronization automatic
network-clock input-source 1 controller E1 0/1/0
network-clock input-source 2 controller E1 0/1/1
07-07-2020 01:57 AM
07-07-2020 02:12 AM
you can also include below to synchronize individual channels.
network-clock synchronization participate slot / subslot
Below samples config
network-clock synchronization participate 0/2
controller E1 0/1/0
framing no-crc4
07-08-2020 04:20 AM
it turns out this command "network-clock select 1 controller E1 x/x/x" isnt needed to begin with
