device registration Unknown
shrutid22
I have CUCM BE 6.1. 2 days back I rebooted the server couple of times for resolving CUP connectivity issues.
After doing this I ran into a problem. All the devices (Phones and Gateway end points) status is unknown while they are functioning fine. All the phones are correctly registered and are working fine but the admin interface shows their status unknown
Any help in this regards is appreciated
Shruti
6 Replies 6
Do you have Pub and Subs or just one server?
if you have more than one servers maybe it is DB replication issue.
try to restart the RIS data collector.
No I have just one server. Business edition
Have you already tried restarting the RIS service?
That's the one that polls the status information for devices
It was already suggested but you don't mention if you did.
java
if this helps, please rate
java
I tried restarting RIS data collector.. No luck
any further possibilities?
Dennis Mink
sounds like the database isnt properly updating phone status via the webpage. If it would be unregistered in the CUCM DB, you would get an engaged tone when dialing any of the unknown devices, which is not the case according to you.
can you reset one of the phones from CUCM admin pages, and see if it's status changes to registered?
Please remember to rate useful posts, by clicking on the stars below.
I tried mentioned above. It didnt help
any further troubleshooting possible?
