DHCP on CCME or Firewall
medzeinmaaloum
Good day,
 I have the following network architecture:
Internet < -- > FortiGate < -- > Cisco Router (CCME) < -- > Cisco IP Phone < -- > PC
The DHCP server must be activated on the FortiGate, dose this is possible?
Best regards,
7 Replies 7
balaji.bandi
As Long as DHCP Server reachable and helper address configure, Routing in place  does not matter where the DHCP Server can be,
BB
If forti support push 66 and op 150 then you can use it' if it not support these op then your VoIP will not get necessary info to work.
MHM
M02@rt37
Hello @medzeinmaaloum
Yes you can configure DHCP server on FortiGate and add on it options configuration ; as example option 150 (tftp server)
Best regards
Hello  M02@rt37
In this case the connection will be:
Internet < -- > FortiGate < -- > Switch
 Cisco Router (CCME) < -- > Switch
PC < -- > Cisco IP Phone < -- > Switch
FortiGate, Cisco Router and Cisco IP Phone equipment must be connected to the same switch.
All of the following part of code (CCME Configuration) must be configured on the Fortigat:
ip dhcp excluded-address 10.40.0.1 10.40.0.10
ip dhcp excluded-address 10.45.0.1 10.45.0.10
ip dhcp pool DATAPOOL
 network 10.40.0.0 255.255.255.0
 default-router 10.40.0.1
ip dhcp pool VOICEPOOL
 network 10.45.0.0 255.255.255.0
 default-router 10.45.0.1
 option 150 ip 10.40.0.1
But there will be a problem with default-router 10.40.0.1 because 10.40.0.1 is the address of the sub router interface, the PCs will not have internet!!!
CCME:
interface GigabitEthernet0/0.40
 encapsulation dot1Q 40
 ip address 10.40.0.1 255.255.255.0
 no ip route-cache
interface GigabitEthernet0/0.45
 encapsulation dot1Q 45
 ip address 10.45.0.1 255.255.255.0
 no ip route-cache
Best regards,
I dont know what is relate of op150 with internet.
If pc can not access internet then issue is in NAT not tftp.
MHM
The problem is linked to the default-router 10.40.0.1, if we put the gateway 10.45.0.1, that is to say that all the equipment will look for GigabitEthernet0/0.45 as a gateway while the IP Phone must look for 10.45.0.1 (Router Interface) but PCs must fetch 10.45.0.254 (Fortigat Interface) to go to the Internet.
best regards,
Friend it different subnet'
You can put iphone gw (make it ip of forti) different than gw for pc.
MHM
