08-14-2012 10:10 AM - edited 03-16-2019 12:42 PM
Good day, everyone!
At last, i've created a h.323 trunk between CME 2901 and Panasonic TDE-200. Calls between local phones are dial well.
On CME i have subscribers with phone number 501 and on Pan TDE-200 - 102. If I dial from 501 to 102 and from 102 to 501, everything is all right.
But, what config should i create to dial to, e.g mobile number 89151893116, through Pan TDE-200, which is connected to service provider through PRI card? Can anyone suggest me please
If i dial from 102 phone number (directly connected to TDE-200), I dial such sequence - 989151893116.
Solved! Go to Solution.
08-14-2012 10:19 AM
You need to add dial-peers that match those digit strings and then ensure Panasonic can route the call out, i.e. ensure the configuration of the trunk has access to outbound routes.
Chris
08-14-2012 10:19 AM
Chris
08-14-2012 11:27 AM
Ok, thanks, tomorrow, i'll try. Panasonic TDE-200, can route calls with such configuration, cause i've another Panasonic TDE-100, which has h.323 trunk to TDE-200. And TDE-100 has access to outbound routes...
