Dial plan between CME 2901 and Panasonic PBX
Dmitri Popkov
Good day, everyone!
At last, i've created a h.323 trunk between CME 2901 and Panasonic TDE-200. Calls between local phones are dial well.
On CME i have subscribers with phone number 501 and on Pan TDE-200 - 102. If I dial from 501 to 102 and from 102 to 501, everything is all right.
But, what config should i create to dial to, e.g mobile number 89151893116, through Pan TDE-200, which is connected to service provider through PRI card? Can anyone suggest me please
If i dial from 102 phone number (directly connected to TDE-200), I dial such sequence - 989151893116.
Chris Deren
You need to add dial-peers that match those digit strings and then ensure Panasonic can route the call out, i.e. ensure the configuration of the trunk has access to outbound routes.
Chris
Chris Deren
Chris
Ok, thanks, tomorrow, i'll try. Panasonic TDE-200, can route calls with such configuration, cause i've another Panasonic TDE-100, which has h.323 trunk to TDE-200. And TDE-100 has access to outbound routes...
