08-18-2010 01:07 AM - edited 03-16-2019 12:18 AM
I am going to upgrade my CUCM from version 7.1.3 to 7.1.5
In 7.1.5 i can see 2 version one for restricted and one for unrestricted.
What is the diffence between these two and what should i use.
Appreciate your reply.
08-18-2010 01:29 AM
Restricted means 'export restricted' - it supports encryption; this is the normal version for countries where encryption is not a legal problem.
Unrestricted means export unrestricted - encryption is disabled, and can't be enabled.
Aaron
08-18-2010 01:50 AM
Hi Aaron
Appreciate your prompt reply.
I have one more query.
It mean to say in unresricted version we are not able to security profile.
And as mentioned in cisco docs, is it not possible to revert back to restricted version once upgraded to unrestricted vesion.
And in future if i want to enable encyption in my unrestricted version , is there any solution for that.
08-18-2010 05:28 AM
According to the release notes; it is not supported to migrated from unrestricted to restricted:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_5/cucm-rel_notes-715.html#wp1768767
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
01-19-2011 08:26 PM
As told by Aaron in unrestricted build we do not have any security option enabled. So you can not enable encryption on unrestricted build.
If you want to have security feature in your setup you need to do fresh install of CUCM restricted version. Remember that you cannot backup unrestricted version and restore on restricted build. You have to configure the restricted CUCM from scratch.
01-19-2011 06:23 PM
I just tried both links and they're working fine.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
