difference between CCM4.1(3) and CCM6.0
K_require
What are the differences between CCM4.1(3) and CCM6.0? Is there any link available?
5 Replies 5
Chris Deren
All CM 4.2, 5.X and 6.X features, I suggest you look through all the release notes for the above for details:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_notes_list.html
HTH,
Chris
Rob Huffman
Hi Abhijit,
Just to add a note to the good tip from Chris (+5 points my friend :)
I did try to summarize the changes recently between 4.1, 4.2, 5.x, 6.x and 7.x :) The doc is attached below;
Hope this helps!
Rob
Hi Rob,
I didnt find any attachment. Can you please upload it again?
Rob Huffman
Let's try that again :)
thanks
