Difference between expansion module
aniket0422
Hello Guys,
What is the difference between CP-8800-V-KEM= and CP-8800-A-KEM=.
Can we use any of the expansion module with Cisco 8851 IP Phone.
7 Replies 7
Ratheesh Kumar
Hi there
CP-8800-V-KEM= - 8800 Series Video KEM, 28 Button
CP-8800-A-KEM= - 8800 Series Audio KEM, 28 Button
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/ip-phone-8865-key-expansion-module/datasheet-c78-739845.html
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/ip-phone-8851-8861-key-expansion-module/datasheet-c78-739846.pdf
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
bichacko
As far as it's usage with 8851 goes;
You can connect upto three 8851/61 Key Expansion Modules to the IP Phone 8861 and up to two 8851/61 KEMs to the IP Phone 8851
and 8851NR.
Bijo
No. We cant mix video expansion module with audio phone and vise versa.
Please refer below link.
https://community.cisco.com/t5/ip-telephony-and-phones/cp-8800-v-kem-does-it-work-with-8851/td-p/3759477
HARIS_HUSSAIN
CP-8800-A-KEM=. should work with 8851.
HARIS_HUSSAIN
CP-8800-V-KEM= will only work with Video Phone of 8800 series
CP-8800-A-KEM= will only work with Audio Phones of 8800 series.
->  CP-8800-A-KEM= is for 8851/8861 IP Phones(A for Audio. Only for Reference)
-> CP-8800-V-KEM= is for 8865 IP Phones (V for Video Phone. Only for Reference)
Wall mount option was not available for 8865 IP Phones.
For what reason are you answering a more than four years old post without adding any substantial new information? That just clutters the board as it brings the post to the top of it.
Response Signature
