Bookmark
Subscribe
8620
Difference between Transformation & Translation Patterns
Syed
Level 3
Level 3
Dear All,
As I understand both Transformation & Translation patterns are used to manipulate calling & called numbers. It would be helpful if someone can assist me with the major difference between these two or related document to make it clear.
Thank you in advance.
2 Accepted Solutions
Nadeem Ahmed
(+5) for deepak for sharing wonderful discussion thread.
:If you have google it there are plenty of documents available on Translation pattern and Transformation why its required and major and minor difference.
There is one thing just keep in mind for Translation and transformation which is nutshell of whole idea behind it and thereafter.
Translation used for digit manipulation before (pre-routing decision made) a destination(GW, Trunk ) is chosen.
Transformation used for digit manipulation after routing decision made like GW trunk is chosen. so its pre-routing for translation and post-routing for transformation which i can say.
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Deepak Rawat
Adding to my previous response in simple words Translation Pattern has the ability to change the destination of a call whereas Transformation Pattern can only change the display i.e., how Calling and Called number will show up as on the phone.
Deepak
Deepak Rawat
Refer to below threads that discuss this in detail:
https://supportforums.cisco.com/discussion/11607256/translation-and-transformation-pattern
https://supportforums.cisco.com/discussion/12697346/difference-between-translation-and-transformation-pattern-and-their-usage
Deepak
Nadeem Ahmed
Br,
Nadeem
Deepak Rawat
Deepak
Thank you Deepak & Nadeem, appreciate your help & support.
