Differences between 6.x and 7.x
fayiz husain
What are the differences between CUCM 6.x and 7.x?
Rob Huffman
Hi Fayiz,
Chris is most correct (+5)
I have tried over the years to capture these notes in the
attached doc. Thanks to Gordon for his contributions;
It's not comprehensive but it should have the info you require.
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
6 Replies 6
Chris Deren
Features and bug fixes, the release notes for any version show the new features added in that version.
HTH,
Chris
Rob Huffman
Hi Fayiz,
Cheers!
Rob
-The Clash
Master Rob! What better way to show your skills, dedication and appetite for learning than this..Awesome! I love it. Nice work
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hey Deji,
WOW!!
Thanks for your very kind words my friend You certainly made my day!
Cheers!
Rob
-The Clash
Chris, Rob, Ayodeji - All good responses here - Round of (+5) to all dedicated contributors.
Fayiz - Please follow the above good advice. I could not stop myself mentioning one of the most notable feature that simplified and changed the Call Routing in CUCM 7 and above, was the addition of Local Route Groups starting version 7. When you move on from CUCM6 to CUCM7 or above make sure you have a good understanding of Local Route Groups and take full advantage of this feature.
Terry.
Hi Fayiz,
Good Document provided by Rob which  gives detail of what all has been introduced in upcoming CUCM versions.
More to add , logical partitioning and Audit log was introduced in CUCM version 7.
regds,
aman
