03-06-2014 02:59 PM - edited 03-16-2019 10:02 PM
Our Reseller quoted us Cisco 2901 Voice Bundle with CUBE-10 Licesne. Will it support CME? or I should go for CME-SRST License? I dont need CUBE feature, so even if it support CME , Am I paying more in the name CUBE license?
Solved! Go to Solution.
03-06-2014 04:01 PM
CME licenses are Right to Use (RTU) which means there are honor based, so technically you can still configure it, however legally you are not entitled to CME without CME licenses. You can always add those on via separate purchase.
HTH,
Chris
03-07-2014 12:12 AM
Just to add for already present answers - Cisco by default included CUBE licenses in recent voice bundles. So for same price you are already given some CUBE RTU licenses which is good because of obvious SIP popularity these days and in the future.
HTH,
Dragan
03-06-2014 03:45 PM
If you need CME then you should be getting the CME bundle with CME/SRST licenses. If you do not require CUBE licenses there is no reason to get them.
HTH,
Chris
03-06-2014 03:57 PM
Thanks Mr. Chris,
In description it mention only CUBE licnese. Is it mean I will not be able to configure CME in that router??
03-06-2014 04:01 PM
HTH,
Chris
03-06-2014 05:33 PM
Thank You
03-07-2014 12:12 AM
HTH,
Dragan
