DIrectory on CME
Santi Cuni
Hello everyone
Could you know which is the URL for the local directory on CME? I want that some phones in the CUCM cluster could access to this directory. I did not find anything on the cisco documentation.
Santi
7 Replies 7
acampbell
This is the URL that the phones use.
http:// IP ADD>:80/localdirectory
Alex
Regards, Alex. Please rate useful posts.
Thanks.However, I could not reach the Directory from a phone registerd on CUCM. Do you have any idea of why?
You don't need URL in CME to enable local directory
But you can let the CME look for external directory : as to CUCM or LDAP directory
Best method is to add your CME users to the CUCM end users then let your CME look to CUCM directory
Haitham
Hi All
thansk for the answers. What I want, is that some phones on CUCM's cluster could be take a look on the CME's Directory. My phones are registered on CUCM, I added a new service with this URL http://:80/localdirectory, however when i try to use the service I receive this error "404 page not found". I need help to fix this issue or maybe a new solution.
Can you try adding this line to the CME config.
Ammend to your CME IP address first.
telephony-service
url directories http:// IP ADDRESS>/localdirectory
Can you also try
show ip http server all | incl ITS
This will confirm that the Directory service is running.
Alex
I did it, but the problem is still present, an aldo I did not understand why says me "404 page not found"...
This has changed in recent CME. The url is now
http:///localdirectory/query
