12-06-2011 07:15 AM - edited 03-16-2019 08:24 AM
Hello everyone
Could you know which is the URL for the local directory on CME? I want that some phones in the CUCM cluster could access to this directory. I did not find anything on the cisco documentation.
Santi
12-06-2011 07:39 AM
This is the URL that the phones use.
http://
Alex
12-06-2011 07:57 AM
Thanks.However, I could not reach the Directory from a phone registerd on CUCM. Do you have any idea of why?
12-06-2011 11:30 AM
You don't need URL in CME to enable local directory
But you can let the CME look for external directory : as to CUCM or LDAP directory
Best method is to add your CME users to the CUCM end users then let your CME look to CUCM directory
Haitham
12-07-2011 12:24 AM
Hi All
thansk for the answers. What I want, is that some phones on CUCM's cluster could be take a look on the CME's Directory. My phones are registered on CUCM, I added a new service with this URL http://
12-07-2011 01:49 AM
Can you try adding this line to the CME config.
Ammend to your CME IP address first.
telephony-service
url directories http://
Can you also try
show ip http server all | incl ITS
This will confirm that the Directory service is running.
Alex
12-07-2011 02:34 AM
I did it, but the problem is still present, an aldo I did not understand why says me "404 page not found"...
01-06-2012 03:08 AM
This has changed in recent CME. The url is now
http://
