Disable CNAM for outgoing calls PRI
UC Support
Do you know the command to strip the CNAM for outgoing calls, currently I have CUCM <---> H.323 GW with 4 PRI (two telcos), using primary-ni and dms100.
I think the comand is under the serial interface.
Note I want to strip the CNAM not the Caller ID.
The goal is that when I make a PSTN call from my IP Phone the PSTN user doesn't see my name (or company name) just the company number.
Thanks in advance.
Carlo
acampbell
Carlo,
Try
no isdn outgoing display-ie
Under the ISDN D-channel
Something like this
interface Serial0/0/0:23
noisdn outgoing display-ie
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Carlo,
Try
Something like this
Alex.
