DMA Backup Configuration Issue-Urgent
Yazen Alaa
I have cucm 7.1.3 , i want to do DMA backup on it , and I have tried many times but unfortunately give me error :
remote file " DMAExportSuccessful03-12-13#18-02" does not exist or cannot read
remote server name or ip : 192.168.50.1
remote file path :  .       and i tried    /
remote file name : DMAExportSuccessful03-12-13#18-02.tar
and i tried withour .tar
remote login : cisco  (it is the same at SFTP)
remote password : 1234 (it is the same at SFTP)
Note : I used FreeFTPD and Mini-SFTP-server
this is SFTP log from FreeFTPD :
03-14-2013 09:02:57 IP 192.168.50.253 SFTP connection attempt
03-14-2013 09:02:58 IP 192.168.50.253 SFTP cisco connected
03-14-2013 09:02:58 IP 192.168.50.253 SFTP cisco is changing dir to / (C:\DMA backup-try\DMAEXPORT\cisco\)
03-14-2013 09:02:58 IP 192.168.50.253 SFTP cisco is listing / (C:\DMA backup-try\DMAEXPORT\cisco\)
03-14-2013 09:02:58 IP 192.168.50.253 SFTP cisco is listing / (C:\DMA backup-try\DMAEXPORT\cisco\DMAEXPORT)
03-14-2013 09:02:58 IP 192.168.50.253 SFTP cisco disconnected
may be the problem is from remote file path and file name
how to solve this issue
thanks
Yazen Alaa
Hi All
Any help PLZ ?
Can you share the exact steps that you are using, starting from the steps on cucm.
1. Were there any errors when you took the DMA
2. How many MB/GB is the file, can you please a different SFTP server, filezilla etc, any cisco supported SFTP server, if the file is more than 1 GB
3. does the sftp user have read/write privileges.
Kunal
Also, looks like u have build the cucm server first and then you are restoring.
From what i remember you need to restore the DMA during the installation.
If you are using DRS GUI to restore DMA i do not think it will work.
If you had no errors on taking the DMA, restore DMA during the installation process, that should work
Kunal
Anas Abueideh
Level 9
Level 9
for DMA you need to import the DMA files in the installation phase. when you install ccm 7.1.3 it will ask you if it is an upgrade from windows version, at that step you will enter SFTP info
Anas
please rate if it is helpful
