09-09-2013 10:46 AM - edited 03-16-2019 07:16 PM
i am finding literature that indicates an external hard drive is required when upgrading appliances on MCS 7825 H3, however, i have a 7825 I4, but i am not finding any lterature that indicates i need the external drive during upgrade.
i am guessing that i may need the external drive since its kind of the same family of servers, but i just need to be sure.
09-09-2013 11:41 AM
Where did you see that? There is no need for any external hard drive, nor is it supported for anything with CUCM. Perhaps you are confusing this with external flash drive which might be helpful to collect install logs should the install fail.
HTH,
Chris
09-09-2013 07:13 PM
Hi Surendra,
In addition to what Mr. Chris has said, you canalways refer the hardware compatibility matrix for MCS servers with desired CUCM version to be upgraded.
regds,
aman
09-10-2013 05:43 AM
Hi guys,
I believe Surendra is referring to this clip;
"For a Refresh Upgrade on HP7825H3 or HP7828H3 hardware from a version prior to Release 8.6(x), use an externally powered USB disk drive with a minimum size of 16 GB to migrate the data from the old system to the new installation. For Unity Connection and Business Edition 5000, an externally powered USB disk drive with a minimum size of 128 GB is required. Cisco recommends that you use an externally powered USB drive, because other drives may not be recognized during the Refresh Upgrade sequence.
Caution | If you are upgrading your software on HP7825H3 or HP7828H3 hardware from a version prior to Release 8.6(x), there is no option to revert to the previous version of Cisco Unified Communications Manager. If you do not back up your system data before starting the software upgrade process, your data will be lost if your upgrade fails. If you chose to revert to the prior version, you must install the prior version and restore your data from your DRS backup." |
From;
There is also this bug;
MCS 7828-H3 and 7825-H3 doesn't boot up after RU with 2 TB External HD
Symptom:
In the document available online there is no explicit mention that we need external drive less than 500 GB or 2 TB. It is only mentioned that you need to have a drive with at least 128 GB.
Conditions:
Refresh Upgrade on MCS 7828-H3 and 7825-H3 using external hard drive more than 500 GB.
COP file installed correctly, upgrade completed successfully to 8.6.2 and above.
Server failed to boot up with newer version.
Error seen on the monitor;
"Unable to download the kickstart file. Please modify the kickstart parameter
below or press Cancel to proceed as an interactive installation"
"3f9845961c1b43a5a2ed2be204d7a9ef71:/refresh_upgrade/ks.cfg"
Workaround:
Here are USB drives that will work for the RU on MCS 7828-H3 and 7825-H3,
1.Thermaltake BlacX ST0005U External Hard Drive SATA Enclosure Docking Station 2.5? & 3.5? USB 2.0 & eSATA. This will take any Desktop SATA hard drive. Inside the enclosure I tested with was a Western Digital WD2500 SATA drive (250GB)
2.Seagate Backup Plus 1TB portable USB drive (no external power)
3.Toshiba 500 Gb Canvio 3.0 USB External Hard Drive (no external power)
I don't believe there is any such requirement for the I4 or H4
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
