08-20-2014 01:35 AM - edited 03-16-2019 11:48 PM
Does the cisco phone 8945 SCCP is compatible with the CME8.5 (on cisco 3825).
Does anyone have tried this?
Antra
Solved! Go to Solution.
08-20-2014 01:58 AM
Hello Antra
No I have not tried this, but according to the compatibility matrix, the 8945 is not supported on CME 8.5.
Here is the compatibility list for CME 8.5:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme85spc-htm.html
or see the full matrix:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
cheers
slashdots
08-20-2014 05:37 AM
The easiest ways to check if a device is supported on the CME:
1. Check compatibility matrix as indicated by slashdots
2. Create a voice register pool or ephone, and then do "type ?", this will give you all the models that are supported in that version of CME.
08-20-2014 01:58 AM
Hello Antra
cheers
slashdots
08-20-2014 05:37 AM
