Does cp-8945 compatible with CME 8.5
iantra123
Level 3
Level 3
Does the cisco phone 8945 SCCP is compatible with the CME8.5 (on cisco 3825).
Does anyone have tried this?
Antra
2 Accepted Solutions
slashdots
Hello Antra
No I have not tried this, but according to the compatibility matrix, the 8945 is not supported on CME 8.5.
Here is the compatibility list for CME 8.5:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme85spc-htm.html
or see the full matrix:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
cheers
slashdots
Sreekanth Narayanan
The easiest ways to check if a device is supported on the CME:
1. Check compatibility matrix as indicated by slashdots
2. Create a voice register pool or ephone, and then do "type ?", this will give you all the models that are supported in that version of CME.
slashdots
Hello Antra
cheers
slashdots
Sreekanth Narayanan
