Does the BE4K support Jabber Phone Only Mode
dwayne rattan
I am trying to get documentation that states BE4K supports Jabber phone only. All documents I have come across only states ATA,7800 and 8800 is supported I have heard and seen on forum that jabber is supported phone only.
2 Accepted Solutions
Jaime Valencia
Jabber is not supported on the BE4K
java
if this helps, please rate
Thanks Jaime,
just had to make sure because there is a video where the guys sound quite convincing and they said  they are working on support forJabber  because its a SIP phone essentially at the 30:30 minute mark : https://www.youtube.com/watch?v=SoR0G03xE2I
I also came across this mislead post in the forum https://community.cisco.com/t5/ip-telephony-and-phones/be4000-softphone-support/td-p/3399800
But with no official documentation I took it with a grain of salt as everything I read does not have reference to jabber at all.
Jaime Valencia
java
Thanks Jaime,
If you want to know about the roadmap for future endpoints/enhancements to the BE4K you would need to do via your SE/AM as that information is NDA, you can ask specifically about Jabber.
java
George Sotiropoulos
Hello Dwane,
In addition to Java's reply, you may also check the following post that includes useful info about BE4K.
https://community.cisco.com/t5/collaboration-voice-and-video/cisco-business-edition-4000-be4k-overview/ta-p/3653101
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
