06-12-2013 12:24 PM - edited 03-16-2019 05:50 PM
We have a router Cisco 3845 wiht some FXO ports connected, the proble we have is this:
If a external user make a call to the PBX, and drop that call before some answered, the router drops this call to an extension like 10 seconds after the call was end by the user, when you pick up the phone there is no active call obviously.
06-12-2013 12:40 PM
Jefferson,
Can we see an example configuration of your fxo ports? Are you using the "connection plar opx"?
Yosh
06-13-2013 12:18 PM
Thanks yashiel
All the ports have the samen configuration:
voice-port 0/0/0
trunk-group PSTN
supervisory disconnect dualtone mid-call
supervisory custom-cptone CR
input gain 5
timeouts call-disconnect 5
timeouts wait-release 5
connection plar 8950
caller-id enable
06-13-2013 12:23 PM
Jefferson,
Try changing the connection plar command to connection plar opx.
Yosh
