DRS not working after upgrade
j.huizinga
Level 6
Level 6
I have upgraded a CUCM 8.5 to 11. The upgrade went OK, can see all devices/users etc. What is not working is the DRS menu.
When I am going to Disaster Recovery System menu, I can see the menu, but whatever I click for example Backup/Backup Device, the browser seems busy but it never displays anything. And this is for all options in the DRS menu. The same is when I execute CLI commands related to DRS, for example I type "utils disaster_recovery device list" and it seems the system is busy, but it never returns anything.
Any has an idea why this is?
I tried all browsers, but for all browsers the same problem.
Has anyone seen this?
JH
Adarsh Chauhan
Level 3
Level 3
Adding to that, please do check ipsec certificates and see that they are not expired on all the nodes.
Please rate if helpful.
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
Rajan
Hi JH,
Are the services up and running ? Pls try restarting the DRF master and DRF local services to see if that helps.
Rajan
Adarsh Chauhan
Level 3
Level 3
Adarsh Chauhan
Adarsh Chauhan
I had the same issue on UCCX 10.6(1)SU2. The IPSec certs were not expired but I regenerated them. rebooted the UCCX cluster and hey presto - DRS was working again.
j.huizinga
Level 6
Level 6
Thanks!
The tomcat and ipsec were expired. After regenerating them all works fine
Jan
