02-28-2012 12:37 AM - edited 03-16-2019 09:48 AM
I tried to add 2 new BRIs to slot 1. After the configuration I'm receiving following error on the gateway (2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(15)T13).
%DSMP-3-DSP_TIMEOUT: DSP timeout on DSP 1/1:1: event 0xDC, DSMP timed out, while waiting for statistics from the DSP. DSMP State = S_DSMP_COLLECTING_STATS, chnl info(1, 1, 1)
When i make a call, the call goes mute.
I have found that there was a bug related to this problem (CSCef90360), but it is not accessible anymore.
show voice dsp error gives me this result:
DSP: 1/1:1
Timeout: 3607180.548 3556041.968 3289057.072 3280658.116
Number of errors overwritten: 1
This is the gateway hardware:
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V08 ,
NAME: "WAN Interface Card - ATM (With multi line G.SHDSL module) on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - ATM (With multi line G.SHDSL module)"
PID: WIC-1SHDSL-V3 , VID: V02 ,
NAME: "2nd generation two port BRI voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation two port BRI voice interface daughtercard"
PID: VIC2-2BRI-NT/TE , VID: V02 ,
NAME: "2nd generation two port BRI voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation two port BRI voice interface daughtercard"
NAME: "4 Port FE Switch on Slot 0 SubSlot 3", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW , VID: V01 ,
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32 , VID: V01 ,
NAME: "High Density Voice Network Module on Slot 1", DESCR: "High Density Voice Network Module"
PID: NM-HD-1V , VID: V01 ,
NAME: "2nd generation two port BRI voice interface daughtercard on Slot 1 SubSlot 0", DESCR: "2nd generation two port BRI voice interface daughtercard"
02-28-2012 01:50 AM
The bug you found (CSCef90360) is being with held by Cisco pending further investigation.
Your current IOS version (c2800nm-spservicesk9-mz.124-15.T13.bin) has beeen deferred (withdrawn) by Cisco due to many bugs.
I would advise you to upgrade to the latest in your train
c2800nm-spservicesk9-mz.124-15.T17.bin
Then re test.
Alex
03-07-2012 01:47 AM
The problem shouldn't be IOS. I have 2 other VGs with the same IOS and configuration and they are OK.
I found another problem that the DSP is changing its status to up only in the end of the call.(when i hang up)
Mar 6 12:58:01.355 MET: ISDN BR1/0/1 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
Mar 6 12:58:01.359 MET: %ISDN-6-CONNECT: Interface BRI1/0/1:1 is now connected to xxxx N/A
Mar 6 12:58:07.359 MET: %ISDN-6-CONNECT: Interface BRI1/0/1:1 is now connected to xxxx N/A
Mar 6 12:58:12.823 MET: %ISDN-6-DISCONNECT: Interface BRI1/0/1:1 disconnected from xxxx , call lasted 11 seconds
Mar 6 12:58:12.823 MET: ISDN BR1/0/1 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x8090 - Normal call clearing
Mar 6 12:58:12.943 MET: ISDN BR1/0/1 Q931: RX <- RELEASE pd = 8 callref = 0x01
Mar 6 12:58:12.943 MET: ISDN BR1/0/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
Mar 6 12:58:14.291 MET: %DSPRM-5-UPDOWN: DSP 1 in slot 1, changed state to up
After each call through this BRI, the Alarm Indicator is increased.
----------------------------FLEX VOICE CARD 1 ------------------------------
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 02 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 03 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 04 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 05 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 06 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 07 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 08 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 09 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 10 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 11 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 12 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 13 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 14 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 15 None 9.4.12 idle idle 58 0 0 0/0
C5510 001 16 None 9.4.12 idle idle 58 0 0 0/0
------------------------END OF FLEX VOICE CARD 1 ----------------------------
I also tried to check the DSP with test voice driver command and reset all DSP's in slot 1 test dsp device 1 all reset, but it didn't help.
I think it can be HW issue. Will try to replace the NM-HD-1V.
03-07-2012 01:51 AM
Sometimes different usage patterns may trigger bugs and it may not be hardware.
If practical I would consider swapping the module and DSPs with another router (you say you have others identically configured) to see if the fault moves with it.
Aaron
03-11-2014 03:41 PM
I have C2951 router, version 15.2 and i got the same error, DSP Timeout and the calls were going mute.
I fixed it reloading the gateway and i haven´t got DSP Timeout erros any more.
By the way i will open TAC to find out why it happened.
04-16-2016 08:31 AM
Did you open TAC ? What did they told you ?
08-16-2023 03:59 AM
Reboot of Router helped me to resolve the issue ..
08-16-2023 05:28 AM
Why are you answering to a post, which is over 10 years old?
Furthermore, probably nobody still uses 2800 routers, they are end of everything for years.
