DSP errors on 2951 voice gateway router
dileepkumar
I am getting below dsp errors on voice gateway router. I believe, we have sufficient DSP resources but still we are getting errors. I tried upgrading the IOS but no luck. We are getting the below errors almost everyday.
Oct  7 10:59:20: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Oct  7 11:00:38: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Oct  7 11:07:18: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Oct  7 11:07:19: %FLEXDSPRM-3-TDM_CONNECT: failed to connect voice-port (2/1/0) to dsp_channel(2/2/7)
Oct  7 11:15:41: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Oct  7 12:50:46: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Oct  8 07:49:57: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Oct  8 07:50:00: %FLEXDSPRM-3-TDM_CONNECT: failed to connect voice-port (2/1/0) to dsp_channel(2/0/3)
Oct  8 07:51:18: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Oct  8 08:13:28: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Here is configuration of the router.
------------------ show version ------------------
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.2(4)M6a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 15-Apr-14 08:12 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
ROU519 uptime is 2 days, 8 hours, 39 minutes
System returned to ROM by reload at 08:08:56 GMT Fri Sep 19 2014
System restarted at 08:11:05 GMT Fri Sep 19 2014
System image file is "flash:c2951-universalk9-mz.SPA.152-4.M6a.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 479232K/45056K bytes of memory.
Processor board ID FCZ161470PB
3 Gigabit Ethernet interfaces
62 Serial interfaces
1 terminal line
2 Channelized E1/PRI ports
16 Voice FXO interfaces
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#       PID             SN
*0      CISCO2951/K9          FCZ161470PB
Technology Package License Information for Module:'c2951'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
------------------ show running-config ------------------
Building configuration...
Current configuration : 15656 bytes
! No configuration change since last restart
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps log datetime
service password-encryption
hostname ROU519
boot-start-marker
boot system flash:c2951-universalk9-mz.SPA.152-4.M6a.bin
boot system flash:c2951-universalk9-mz.SPA.152-3.T2.bin
boot system flash:c2951-universalk9-mz.SPA.151-3.T4.bin
boot-end-marker
card type e1 2 1
logging buffered 16000
enable secret 4 z6DgK0gnLR/f8q5XhbEqWZs0faYG018Pu1/MY3x0Dog
aaa new-model
aaa authentication login default group radius local
aaa authentication login support local none
aaa session-id common
clock timezone GMT 4 0
network-clock-participate slot 2
network-clock-select 1 E1 2/0
no ip source-route
ip cef
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
trunk group FXOPORTS
 hunt-scheme round-robin
trunk group PRI
 hunt-scheme sequential
voice-card 0
 dspfarm
 dsp services dspfarm
voice-card 2
 dspfarm
voice rtp send-recv
voice service voip
 ip address trusted list
  ipv4 10.1.3.243 255.255.255.255
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback cisco
 h323
 sip
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
 codec preference 3 g729br8
 codec preference 4 g711alaw
voice class h323 1
  h225 timeout tcp establish 3
voice class dualtone-detect-params 1
 freq-max-deviation 25
 freq-max-power 0
 freq-min-power 13
 freq-power-twist 4
 cadence-variation 4
voice class custom-cptone UAE-CUSTOM-ALCATEL
 dualtone disconnect
  frequency 425
  cadence 375 375
voice translation-rule 1
 rule 1 /^37183/ /3037777/
 rule 2 /^37184/ /3037777/
 rule 3 /^37389/ /3037777/
 rule 4 /^37390/ /3037777/
 rule 5 /^37105/ /3037777/
 rule 6 /^37596/ /3037777/
 rule 7 /^37658/ /3037777/
 rule 8 /^37659/ /3037777/
 rule 9 /^37668/ /3037777/
 rule 10 /^37892/ /3037777/
 rule 11 /^37781/ /3037777/
 rule 12 /^37669/ /3037777/
 rule 13 /^37092/ /3037777/
 rule 14 /^37131/ /3037777/
 rule 15 /^37135/ /3037777/
voice translation-rule 2
 rule 1 /[0-9]+/ /9&/
voice translation-rule 3
 rule 1 /002/ /7777/
 rule 2 /003/ /7777/
 rule 3 /005/ /7777/
 rule 4 /006/ /7777/
 rule 5 /007/ /7777/
 rule 6 /008/ /7777/
 rule 7 /009/ /7777/
 rule 8 /010/ /7777/
 rule 9 /011/ /7777/
 rule 10 /015/ /7777/
 rule 11 /016/ /7777/
 rule 12 /017/ /7777/
 rule 13 /018/ /7777/
 rule 14 /019/ /7777/
 rule 15 // /7&/
voice translation-rule 5
 rule 1 /^3879400/ /7025/
voice translation-rule 6
 rule 1 /^3718[34]/ /3037777/
 rule 2 /^37389/ /3037777/
 rule 3 /^37105/ /3037777/
 rule 4 /^3759[56]/ /3037777/
 rule 5 /^3765[89]/ /3037777/
 rule 6 /^3766[89]/ /3037777/
 rule 7 /^37092/ /3037777/
 rule 8 /^37131/ /3037777/
 rule 9 /^37752/ /3037777/
 rule 10 /^37731/ /3037777/
 rule 12 /^37892/ /3037777/
 rule 13 /^37390/ /3037777/
 rule 14 /^3776[89]/ /3037777/
 rule 15 /^3777[01]/ /3037777/
 rule 16 /^3701[01356789]/ /3037777/
 rule 17 /^3700./ /3037777/
 rule 18 /^37.../ /30&/
voice translation-profile FROM_PSTN
 translate calling 2
 translate called 3
voice translation-profile FROM_PSTN2
 translate called 5
voice translation-profile TO_PSTN
 translate calling 6
voice translation-profile atmac
 translate called 6
license udi pid CISCO2951/K9 sn FCZ161470PB
hw-module pvdm 0/0
hw-module sm 2
username cisco password 7 <removed>
redundancy
controller E1 2/0
 pri-group timeslots 1-31
 trunk-group PRI timeslots 1-31
controller E1 2/1
 framing NO-CRC4
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 encapsulation dot1Q 10
 ip address 10.25.0.3 255.255.255.0
interface GigabitEthernet0/0.210
 encapsulation dot1Q 210
 ip address 192.168.210.4 255.255.255.0
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 192.168.210.4
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial2/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
interface Serial2/1:15
 no ip address
 encapsulation hdlc
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.210.1
ip radius source-interface GigabitEthernet0/0.10
nls resp-timeout 1
cpd cr-id 1
snmp-server community <removed> RW
snmp-server community <removed> RO
snmp-server enable traps entity-sensor threshold
radius-server host 10.1.5.211 key 7 <removed>
radius-server vsa send authentication
control-plane
voice-port 0/0/0
 trunk-group FXOPORTS
 supervisory disconnect dualtone mid-call
 supervisory custom-cptone UAE-CUSTOM-ALCATEL
 supervisory dualtone-detect-params 1
 input gain 14
 timeouts call-disconnect 1
 timeouts wait-release 1
 timing hookflash-out 50
 connection plar opx 37777
 caller-id enable
voice-port 0/0/1
 input gain 14
 caller-id enable
voice-port 0/0/2
 input gain 14
 caller-id enable
voice-port 0/0/3
 input gain 14
 caller-id enable
voice-port 0/1/0
 input gain 14
 caller-id enable
voice-port 0/1/1
 input gain 14
 caller-id enable
voice-port 0/1/2
 input gain 14
 caller-id enable
voice-port 0/1/3
 input gain 14
 caller-id enable
voice-port 0/2/0
 input gain 14
 caller-id enable
voice-port 0/2/1
 input gain 14
 caller-id enable
voice-port 0/2/2
 input gain 14
 caller-id enable
voice-port 0/2/3
 input gain 14
 caller-id enable
voice-port 0/3/0
 input gain 14
 caller-id enable
voice-port 0/3/1
 input gain 14
 caller-id enable
voice-port 0/3/2
 input gain 14
 caller-id enable
voice-port 0/3/3
 input gain 14
 caller-id enable
voice-port 2/0:15
 translation-profile incoming FROM_PSTN
voice-port 2/1:15
 translation-profile incoming FROM_PSTN2
mgcp profile default
sccp local GigabitEthernet0/0.210
sccp ccm 192.168.210.22 identifier 1 priority 1 version 7.0
sccp ccm 192.168.210.21 identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register CFB-ATMC
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 2
 associate application SCCP
dial-peer voice 151 voip
 destination-pattern 799[83]
 session protocol sipv2
 session target ipv4:10.1.3.243
 session transport udp
 dtmf-relay sip-notify
 codec g711ulaw
 fax rate 14400
 fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback none
dial-peer voice 152 voip
 destination-pattern 7678
 codec g711ulaw
 fax rate 14400
dial-peer voice 153 voip
 destination-pattern 7071
 codec g711ulaw
 fax rate 14400
dial-peer voice 154 voip
 destination-pattern 7172
 codec g711ulaw
 fax rate 14400
dial-peer voice 155 voip
 destination-pattern 7374
 codec g711ulaw
 fax rate 14400
dial-peer voice 156 voip
 destination-pattern 7576
 codec g711ulaw
 fax rate 14400
dial-peer voice 157 voip
 destination-pattern 77[56]1
 codec g711ulaw
 fax rate 14400
dial-peer voice 158 voip
 destination-pattern 7778
 codec g711ulaw
 fax rate 14400
dial-peer voice 159 voip
 destination-pattern 7879
 codec g711ulaw
 fax rate 14400
dial-peer voice 160 voip
 destination-pattern 7703
 codec g711ulaw
 fax rate 14400
dial-peer voice 161 voip
 destination-pattern 7699
 codec g711ulaw
 fax rate 14400
dial-peer voice 101 voip
 preference 1
 destination-pattern 7...
 session target ipv4:192.168.210.22
 voice-class codec 1
 voice-class h323 1
 dtmf-relay h245-alphanumeric
dial-peer voice 102 voip
 huntstop
 preference 2
 session target ipv4:192.168.210.21
 voice-class codec 1
 voice-class h323 1
dial-peer voice 203 pots
 trunkgroup FXOPORTS
 trunkgroup PRI
 translation-profile outgoing TO_PSTN
 destination-pattern 904.......$
 incoming called-number .
 direct-inward-dial
 prefix 04
dial-peer voice 201 pots
 trunkgroup FXOPORTS
 trunkgroup PRI
 destination-pattern 9[1-9]T
 direct-inward-dial
dial-peer voice 202 pots
 trunkgroup PRI
 trunkgroup FXOPORTS
 destination-pattern 90[0-9]T
 direct-inward-dial
 prefix 088880
gatekeeper
 shutdown
banner exec ^CThis is a private network system operated for and by Al Tayer Group.Authorization from Al Tayer Group is required to use this system.Any unauthorized access to the system is prohibited^C
banner login ^CThis is a private network system operated for and by Al Tayer Group.Authorization from Al Tayer Group is required to use this system.Any unauthorized access to the system is prohibited^C
banner motd ^CThis is a private network system operated for and by Al Tayer Group.Authorization from Al Tayer Group is required to use this system.Any unauthorized access to the system is prohibited^C
line con 0
 exec-timeout 5 0
line aux 0
 exec-timeout 0 10
 no exec
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 5 0
 transport input all
line vty 5 15
 transport input all
scheduler allocate 20000 1000
ntp server 10.1.2.42
event manager applet dsperror
 event syslog pattern "%FLEXDSPRM-5-OUT_OF_RESOURCES:"
 action 1.0 cli command "en"
 action 1.1 cli command "show voice dsp active | append flash:dsperror.txt"
 action 1.2 syslog msg "command excecuted"
end
11 Replies 11
Tagir Temirgaliyev
I had problem like this with dsp
only cisco tac solved it
after many and many voice related debugs and packet captures
how many dsp do you have?
how many calls do you have?
sh call voic med com
sh voice dsp group all            -   in case of failure and not
I don't think so it's DSP resources issue. We have enough DSPs available, even the error can come in non peak hours.
Please find output of "sh voice dsp group all ", as I did not find the first command.
ROU519#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 32.1.5
  Max signal/voice channel: 43/43
  Max credits: 645, Voice credits: 645, Video credits: 0
  num_of_sig_chnls_allocated: 16
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 624, reserved credits: 0
    Signaling channels allocated: 16
    Voice channels allocated: 1
    Credits used (rounded-up): 21
    Voice channels:
      Ch01: voice port: 0/1/1, codec: g729br8, credits allocated: 20
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 2:
   num_of_sig_chnls_allocated: 0
    Shared credits: 645, reserved credits: 0
    Signaling channels allocated: 0
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 3:
  Max signal/voice channel: 42/43
    Shared credits: 460, reserved credits: 0
   Group: FLEX_GROUP_CONF, complexity: CONFERENCE
    Shared credits: 0, reserved credits: 185
    Codec: CONF_G729, maximum participants: 8
    Sessions per dsp: 7
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
DSP groups on slot 1:
 This command is not applicable to slot 1
DSP groups on slot 2:
dsp 1:
  Max signal/voice channel: 16/16
  Max credits: 240
    Shared credits: 210, reserved credits: 0
    Credits used (rounded-up): 30
    Voice channels:
      Ch01: voice port: 2/0:15.4, codec: g729br8, credits allocated: 30
dsp 2:
  Max credits: 240
  num_of_sig_chnls_allocated: 12
    Shared credits: 150, reserved credits: 0
    Signaling channels allocated: 12
    Voice channels allocated: 3
    Credits used (rounded-up): 90
    Voice channels:
      Ch01: voice port: 2/0:15.6, codec: g729r8, credits allocated: 30
      Ch02: voice port: 2/0:15.10, codec: g729br8, credits allocated: 30
      Ch03: voice port: 2/0:15.11, codec: g729br8, credits allocated: 30
dsp 3:
  Max credits: 240
    Voice channels:
      Ch01: voice port: 2/0:15.1, codec: g729br8, credits allocated: 30
      Ch02: voice port: 2/1:15.17, codec: g729br8, credits allocated: 30
      Ch03: voice port: 2/0:15.3, codec: g729r8, credits allocated: 30
dsp 4:
  Max credits: 240
    Shared credits: 180, reserved credits: 0
     Voice channels allocated: 2
    Credits used (rounded-up): 60
    Voice channels:
      Ch01: voice port: 2/0:15.5, codec: g729r8, credits allocated: 30
      Ch02: voice port: 2/0:15.2, codec: g729br8, credits allocated: 30
DSP groups on slot 3:
 This command is not applicable to slot 3
DSP groups on slot 4:
 This command is not applicable to slot 4
  2081 DSP resource allocation failure
ROU519#
ROU519#sh logg
Syslog logging: enabled (0 messages dropped, 55 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 1679 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 1731 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 1730 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (16000 bytes):
Nov  2 08:09:19: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:07:19: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:07:47: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:08:20: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:22:48: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:22:54: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:23:06: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:23:16: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:23:21: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:23:55: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  2 11:24:24: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:24:52: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:25:02: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:25:30: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 11:26:19: %SYS-5-CONFIG_I: Configured from console by ialii on vty0 (10.100.41.29)
Nov  2 11:26:37: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  2 12:14:29: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 07:13:12: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 07:13:18: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 07:13:24: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 07:14:17: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 07:14:23: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  3 07:15:04: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 08:02:07: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 08:02:19: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 08:02:35: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 08:02:55: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 08:03:36: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 08:26:21: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 08:26:29: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 08:26:43: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 08:27:51: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 11:30:37: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 11:31:40: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  3 11:31:46: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:12:37: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:12:44: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:21:03: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:21:10: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:21:30: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:31:46: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:32:03: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:32:17: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:32:33: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:32:39: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:32:46: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  3 12:32:53: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:32:59: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:33:09: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:33:27: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:33:36: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:33:43: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:33:51: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:33:59: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:34:06: %FLEXDSPRM-3-TDM_CONNECT: failed to connect voice-port (2/1/0) to dsp_channel(2/1/2)
Nov  3 12:40:31: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:40:54: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:45:50: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  3 12:46:13: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:56:11: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:58:05: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 12:58:21: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  3 13:06:50: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  4 10:42:40: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  4 10:43:04: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  6 07:49:20: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 06:54:05: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 06:54:22: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 06:54:28: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 06:55:24: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  9 06:57:37: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 06:57:57: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 06:58:10: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 06:58:21: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:15:38: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:30:35: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:32:10: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:32:28: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:32:34: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:32:46: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:33:09: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:33:20: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  9 07:33:30: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:34:00: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:34:10: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:37:01: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:37:07: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:37:40: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:38:06: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:38:12: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:41:15: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:41:31: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:41:36: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:41:49: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  9 07:41:56: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:42:04: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:42:12: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:42:19: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:42:29: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:43:20: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:43:23: %FLEXDSPRM-3-TDM_CONNECT: failed to connect voice-port (2/1/0) to dsp_channel(2/1/3)
Nov  9 07:43:49: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:46:34: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:46:50: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:49:17: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:49:25: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  9 07:49:32: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:55:25: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:55:51: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:56:20: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:56:33: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:56:39: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 07:56:48: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 08:03:40: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 08:03:46: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 08:05:28: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 08:39:36: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 09:23:38: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  9 09:23:58: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 09:32:11: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 09:32:50: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 10:43:29: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:09:06: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:09:13: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:09:23: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:11:10: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:11:22: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:11:43: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:11:51: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:11:58: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  9 11:12:03: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:12:08: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:12:14: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:12:37: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:12:45: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:13:02: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:49:14: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 11:49:19: %FLEXDSPRM-3-TDM_CONNECT: failed to connect voice-port (2/1/0) to dsp_channel(2/0/7)
Nov  9 11:51:26: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 13:11:03: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 13:12:31: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov  9 13:12:44: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov  9 13:13:26: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 10 07:19:31: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 10 07:21:35: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 10 07:31:40: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 10 08:13:13: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 10 08:25:40: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 10 08:25:51: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 10 08:25:57: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 10 15:21:14.649: //-1/0B59AA678F7B/CCAPI/cc_api_call_setup_ind_common:
   Sub Calling(TON=Unknown, NPI=Unknown, Data=802, Length=5)
Nov 11 07:17:07: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 11 07:41:59: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 11 11:11:42: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov 11 11:11:56: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 11 12:18:03: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 11 12:48:39: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 11 12:48:46: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 11 12:51:32: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 07:38:56: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 07:39:03: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 07:39:11: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 07:39:45: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 07:40:13: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 07:40:19: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 07:40:27: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
 Nov 12 07:40:34: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 07:43:22: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 07:43:24: %FLEXDSPRM-3-TDM_CONNECT: failed to connect voice-port (2/1/0) to dsp_channel(2/3/5)
Nov 12 08:02:58: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 12:17:22: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 12:18:46: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 12:18:56: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 12:19:48: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 12:19:56: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Nov 12 12:47:55: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
ROU519#
I see you have pvdm3-128 installed
try another ios
no boot system flash:c2951-universalk9-mz.SPA.152-4.M6a.bin
and router will load next ios
Hi Tagir,
I tried with both below IOS, but still getting the same error. Do you think is there any issue in the DSP allocation or configuration of it??
can you try running the command debug dspfarm all and check the status for any lack of DSPs
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/25109-DSPFarm-Reg.html
debug dspfarm all
VG200(config)#
no dspfarm
VG200(config)#
dspfarm
00:09:26: dspfarm_process_startup: dspfarm process (id=2) started.
00:09:28: dsp id 8 state 3
00:09:28: dsp id 7 state 3
00:09:28: dsp id 6 state 3
00:09:28: dsp id 5 state 3
00:09:28: dsp id 4 state 3
00:09:28: dsp id 3 state 3
00:09:28: dsp id 2 state 3
00:09:28: dsp id 1 state 3
00:09:28: dsp id 0 state 3
00:09:28: dspfarm_dsprm_enable:max_xcode 32 max_conf 5 num_card 1 num_dsp 9
00:09:28: dsprm_get_max_xcode_dsp: value 8
00:09:28: dspfarm_dsprm_enable:max_conf_dsp 5 max_xcode_dsp 8
00:09:28: dspfarm_dsprm_enable:DSPfarm config exceed total DSPs 9 in the system
00:09:28: DSPfarm config exceed total DSPs (9) in the system
00:09:28: dspfarm_xapp_enq: Sent msg 1 to DSPFARM
00:09:28: dspfarm_process_dsp_event_queue: DSP eve 80EEBD50 rcvd
regds,
aman
Do you do not have port 2/1/0? I didn't see this port in your gateway config..So this has to be a bug. If you do not have this port, why would the gateway be trying to allocate dsp for the port? That suggest its a BUG. This is the only port the error referencing
Please rate all useful posts
Yes, I do understand that there is no port "2/1/0" on voice gateway router, but whats the workaround of this buggy behavior. Upgrading the IOS did not resolve the issue.
This is definitely a bug. You don't event have those ports 2/1/0 configured on your gateway.
This is the link that describes the bug.
https://tools.cisco.com/bugsearch/bug/CSCuj64211
Hi Ayodeji,
I have seen the bug but the workaround is to restart which I have done couple of time but no luck. Even I tried with different below IOS but still same error logs are coming.
Ayodeji Okanlawon
It is possible that some of your dsps are bad or you do not have enough dsps..
Please send the ff:
show voice dsp voice
show diag
Hi Ayodeji,
Please find the output of both commands. We have enough DSPs.
ROU519#              sh voice dsp voice
 DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
 TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
 ----------------------------FLEX VOICE CARD 0 -----------------------
                            *DSP VOICE CHANNELS*
 CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
 LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
 TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
 SP2600 001 01 g729br8       32.1.5 busy  idle      0  0 0/1/1     04    0    1971/2869
 SP2600 001 02 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 03 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 04 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 05 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 06 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 07 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 08 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 09 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 10 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 11 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 12 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 13 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 14 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 15 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 16 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 17 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 18 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 19 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 20 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 21 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 22 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 23 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 24 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 25 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 26 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 27 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 28 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 29 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 30 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 31 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 32 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 33 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 34 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 35 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 36 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 37 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 38 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 39 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 40 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 41 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 42 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 001 43 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 01 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 02 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 03 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 04 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 05 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 06 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 07 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 08 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 09 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 10 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 11 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 12 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 13 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 14 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 15 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 16 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 17 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 18 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 19 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 20 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 21 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 22 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 23 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 24 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 25 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 26 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 27 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 28 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 29 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 30 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 31 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 32 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 002 33 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 34 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 35 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 36 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 37 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 38 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 39 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 40 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 41 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 42 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 002 43 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 01 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 003 02 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 03 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 04 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 05 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 06 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 07 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 08 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 09 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 10 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 11 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 12 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 13 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 003 14 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 15 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 16 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 17 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 18 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 19 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 20 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 21 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 22 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 23 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 24 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 25 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 003 26 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 27 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 28 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 29 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 30 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 31 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 32 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 33 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 34 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 35 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 36 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 37 None          32.1.5 idle  idle      0  0                 0          0/0
 SP2600 003 38 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 39 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 40 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 41 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 42 None          32.1.5 idle  idle      0  0                 0          0/0
SP2600 003 43 None          32.1.5 idle  idle      0  0                 0          0/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
----------------------------FLEX VOICE CARD 2 -----------------------
C5510  001 01 g729r8        32.1.5 busy  idle      0  0 2/0:15    04    0      486/945
C5510  001 02 g729br8       32.1.5 busy  idle      0  0 2/0:15    07    0      333/579
C5510  001 03 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 04 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 05 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 06 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 07 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 08 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 09 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 10 None          32.1.5 idle  idle      0  0                 0          0/0
 C5510  001 11 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 12 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 13 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 14 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 15 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  001 16 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 01 g729r8        32.1.5 busy  idle      0  0 2/0:15    06    0   4968/23224
C5510  002 02 g729br8       32.1.5 busy  idle      0  0 2/0:15    10    0    1891/4649
C5510  002 03 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 04 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 05 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 06 None          32.1.5 idle  idle      0  0                 0          0/0
 C5510  002 07 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 08 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 09 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 10 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 11 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 12 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 13 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 14 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 15 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  002 16 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 01 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 02 g729br8       32.1.5 busy  idle      0  0 2/1:15    17    0   5507/11970
 C5510  003 03 g729br8       32.1.5 busy  idle      0  0 2/0:15    03    0   5944/10244
C5510  003 04 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 05 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 06 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 07 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 08 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 09 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 10 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 11 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 12 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 13 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 14 None          32.1.5 idle  idle      0  0                 0          0/0
 C5510  003 15 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  003 16 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 01 g729br8       32.1.5 busy  idle      0  0 2/0:15    05    0     589/1639
C5510  004 02 g729br8       32.1.5 busy  idle      0  0 2/0:15    02    0    4563/7301
C5510  004 03 g729br8       32.1.5 busy  idle      0  0 2/0:15    11    0     928/1775
C5510  004 04 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 05 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 06 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 07 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 08 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 09 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 10 None          32.1.5 idle  idle      0  0                 0          0/0
 C5510  004 11 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 12 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 13 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 14 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 15 None          32.1.5 idle  idle      0  0                 0          0/0
C5510  004 16 None          32.1.5 idle  idle      0  0                 0          0/0
------------------------END OF FLEX VOICE CARD 2 ----------------------------
ROU519#
ROU519#sh diag
Slot 0:
C2951 Mother board 3GE, integrated VPN and 4W Port adapter, 19 ports
Port adapter is analyzed
Port adapter insertion time 7w5d ago
EEPROM contents at hardware discovery:
PCB Serial Number        : FOC161005DH
Hardware Revision        : 1.1
Part Number              : 73-11836-07
Top Assy. Part Number    : 800-30793-05
Board Revision           : A0
Deviation Number         : 122364
Fab Version              : 03
Product (FRU) Number     : CISCO2951/K9
Version Identifier       : V05
CLEI Code                : CMMBM00ARC
Processor type           : C8
Chassis Serial Number    : FCZ161470PB
Chassis MAC Address      : 5057.a8bd.9040
MAC Address block size   : 96
Manufacturing Test Data  : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
 0x00: 04 FF C1 8B 46 4F 43 31 36 31 30 30 35 44 48 40
   0x10: 06 15 41 01 01 82 49 2E 3C 07 C0 46 03 20 00 78
 0x20: 49 05 42 41 30 88 00 01 DD FC 02 03 CB 8C 43 49
 0x30: 53 43 4F 32 39 35 31 2F 4B 39 89 56 30 35 20 D9
 0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 4D 30 30 41 52
 0x50: 43 09 C8 C2 8B 46 43 5A 31 36 31 34 37 30 50 42
 0x60: C3 06 50 57 A8 BD 90 40 43 00 60 C4 08 00 00 00
 0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
 0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Internal Power Supply information
Top Assy. Part Number    : 341-0226-03
Deviation Number         : 0
PCB Serial Number        : QCS1550H597
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
Version Identifier       : V03
  Product (FRU) Number     : PWR-2921-51-AC
CLEI Code                : 0000000000
Board Revision           : A0
 0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 03 88 00 00 00
 0x10: 00 C1 8B 51 43 53 31 35 35 30 48 35 39 37 03 00
 0x20: 81 00 00 00 00 04 00 89 56 30 33 20 CB 8E 50 57
 0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
 0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
 0x50: 05 F8 00 50 01 F4 14 41 02 EE 16 F0 03 E8 18 C9
 0x60: 04 E2 1A 76 05 DC 1B 91 06 D6 1C 78 07 D0 1D 10
 0x70: 08 CA 1D 9E 09 C4 1E 6D 0A BE 1E A8 0B B8 1F 5E
 0x80: 0D AC 20 FB 0F A0 21 18 11 94 21 64 13 88 21 71
 0x90: 17 70 21 9F 1B 58 21 96 1F 40 21 6D 23 28 21 62
 0xA0: 27 10 21 5A 42 41 30 FF FF FF FF FF FF FF FF FF
PVDM Slot 0:
  128-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
Hardware Revision        : 1.0
Part Number              : 73-11810-03
Board Revision           : C0
Fab Version              : 03
PCB Serial Number        : FOC16041LZS
RMA History              : 00
Processor type           : 00
Product (FRU) Number     : PVDM3-128
Version Identifier       : V01
 0x00: 04 FF 40 05 DC 41 01 00 82 49 2E 22 03 42 43 30
 0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 30 34
 0x20: 31 4C 5A 53 03 00 81 00 00 00 00 04 00 09 00 CB
 0x30: 8F 50 56 44 4D 33 2D 31 32 38 20 20 20 20 20 20
 0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
2nd generation - FXO Voice daughter card (4 port)
Hardware Revision        : 5.0
Top Assy. Part Number    : 800-21589-01
Board Revision           : E0
Deviation Number         : 0-0
Fab Version              : 04
PCB Serial Number        : FOC09022P3U
RMA History              : 00
Product (FRU) Number     : VIC2-4FXO=
 0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 01
 0x10: 42 45 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 30
 0x20: 39 30 32 32 50 33 55 03 00 81 00 00 00 00 04 00
 0x30: 89 56 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
 0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
Board Revision           : E0
Fab Version              : 04
PCB Serial Number        : FOC09022NAA
RMA History              : 00
 0x20: 39 30 32 32 4E 41 41 03 00 81 00 00 00 00 04 00
WIC Slot 2:
Board Revision           : E0
Fab Version              : 04
PCB Serial Number        : FOC09052SJ9
RMA History              : 00
 0x20: 39 30 35 32 53 4A 39 03 00 81 00 00 00 00 04 00
WIC Slot 3:
Board Revision           : E0
Fab Version              : 04
PCB Serial Number        : FOC09022NP2
RMA History              : 00
 0x20: 39 30 32 32 4E 50 32 03 00 81 00 00 00 00 04 00
Slot 2:
SM-NM-ADPTR
Port Adapter is analyzed
Port Adapter insertion time 7w5d ago
PCB Serial Number        : FOC16100PPH
Part Number              : 73-12434-04
Top Assy. Part Number    : 800-32481-01
Board Revision           : F0
Fab Version              : 05
RMA History              : 00
Product (FRU) Number     : SM-NM-ADPTR
 0x00: 04 FF C1 8B 46 4F 43 31 36 31 30 30 50 50 48 40
 0x10: 05 F4 41 01 00 82 49 30 92 04 C0 46 03 20 00 7E
 0x20: E1 01 42 46 30 88 00 00 00 00 02 05 03 00 81 00
 0x30: 00 00 00 04 00 CB 8B 53 4D 2D 4E 4D 2D 41 44 50
 0x40: 54 52 89 56 30 31 00 D9 03 40 C1 CB F3 00 03 40
 0x50: 0B E3 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
High Density Voice NM-HDV2-2T1/E1 Port adapter
Top Assy. Part Number    : 800-22168-02
Board Revision           : B0
Fab Version              : 04
PCB Serial Number        : FOC09012762
RMA History              : 00
  Fab Part Number          : 28-6126-04
Field Diagnostics Data   : 00 00 00 00 00 00 00 00
Product (FRU) Number     : NM-HDV2-2T1/E1
Version Identifier       : V02
 0x00: 04 FF 40 03 DB 41 01 01 C0 46 03 20 00 56 98 02
 0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 30
 0x20: 39 30 31 32 37 36 32 03 00 81 00 00 00 00 04 00
 0x30: 85 1C 17 EE 04 C4 08 00 00 00 00 00 00 00 00 C5
 0x40: 08 00 00 00 00 00 00 00 00 CB 8E 4E 4D 2D 48 44
 0x50: 56 32 2D 32 54 31 2F 45 31 89 56 30 32 20 D9 02
 0x60: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FPGA revision:0x16C
WIC Slot 1:
HDV2 on board t1/e1 controller (2 port)
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
  Hardware Revision        : 3.2
Part Number              : 73-8541-04
Board Revision           : A0
Fab Version              : 03
PCB Serial Number        : FOC09033GMR
RMA History              : 00
Processor type           : 00
Product (FRU) Number     : PVDM2-64
Version Identifier       : NA
 0x00: 04 FF 40 03 EC 41 03 02 82 49 21 5D 04 42 41 30
 0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 30 39 30 33
 0x20: 33 47 4D 52 03 00 81 00 00 00 00 04 00 09 00 CB
 0x30: 88 50 56 44 4D 32 2D 36 34 89 4E 41 20 20 D9 02
 0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x20000000
  Number of blocks of memory for 2nd core : 1
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
