DSP resetting after alarms - Calls Dropped
andyhibbert
Every hour or so I get the following error message on my voice gateway
%DSPRM-3-DSPALARM: Received alarm indication from dsp (0/1). Resetting the DSP.
%DSPRM-3-DSPALARMINFO: 002A 0000 0080 0000 0008 0008 5761 7463 6844 6F67 2054 696D 656F 7574 2C20 5043 3D30 3030 6539 3663 3400 4E5F 0000 0000 0000
%DSPRM-3-DSPALARMINFO: WatchDog Timeout, PC=000e96c4
DSP trace buffer dump for DSP 0/1
DSP version: 26.3.8
Trace buffer size: 1392 bytes
===== Begining of DSP tracebuffer dump=====
DSPTB0:00058DD0 00057945 00057944 00057ADB 00057AC6 0014542D 00145428
etc
etc
Is this likely to be a caused by a faulty DSP module or could it be a IOS configuration error or a problem with the PSTN connection?
The hardware is a Cisco 2921 router running C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M4.
The PSTN interface card is VWIC2-2MFT-T1/E1.
There is a PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4
There is a PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 5
Andy
dijohn
Workaround: use default value as 128ms.
=> Change ALL the voice-ports and have echo-cancel coverage configured
to 128 (default value)
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&b
ugId=CSCtj71414
voice-port 0/2/0:15    echo-cancel coverage 128
dijohn
This is due to
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtj71414
Symptom: dsp crash
Conditions: when max tali lehgth of ecan is configure smaller than 80 ms.
/divin
PS: Rate useful posts!
dijohn
ugId=CSCtj71414
Solved my problem too. Thanks for your post.
I performed this procedure but I'm still getting the same log, even after clearing the logging.
