DTMF missing in outbound calls, specific scenario
Marek.Jiricek
Hello all,
i'll appreciate any help with my DTMF issue, here is quick overview:
Cisco IP Phone 7941 SCCP/SIP -> CUCM 8.6 -> GW Router 2801 (ipipgw 12.4(24)T8) -> ASA FW -> SIP Trunk provider.
SIP Provider is using DTMF SIP INFO method (inband-voice in SIP signalization).
For inbound calls dtmf works fine, problem is with an outbound calls (initiating call in-to-out) on 7941. I was testing 7940 SIP and it worked fine in both directions, but it needs to be working on 7941 as well as on 7940.
I did a lot of troubleshooting and configuring about this kind of behaviour, but nothing solved this issue.
I guess I can provide you packet captures on CUCM, GW for using with SW Wireshark and a debug on GW. Whatever will help us to find the source and solution of this issue.
Thanks a lot for any advice and ideas while also apologize for non perfect english.
With best regards
Mark
In the attach I give you last output from "debug ccsip mess..." command on R2801 (both non/working DTMF on 7941/7940 SIP) and its probably very common config (one of many setup).
From the logs..I can see that the invite sent out to ITSP does not cotain any DTMF attributes...
Sent:
INVITE sip:800123456@188.175.113.182:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.105.20:5060;branch=z9hG4bK18911A
To: <800123456>
Date: Mon, 08 Apr 2013 15:46:30 GMT
Call-ID: 509B2AE6-9F9A11E2-9377CDA1-7BDD1AAB@192.168.105.20
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2902615296-65536-460-359246016
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1365435990
Contact: <226805813>
Expires: 180
Allow-Events: kpml, telephone-event
Max-Forwards: 68
Session-Expires:  1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 197
v=0
o=CiscoSystemsSIP-GW-UserAgent 3604 6815 IN IP4 192.168.105.20
s=SIP Call
c=IN IP4 192.168.105.20
t=0 0
m=audio 17736 RTP/AVP 8
a=rtpmap:8 PCMA/8000
a=ptime:20
---------------------------------------------------------no DTMF attribute
Look below and see the invite from CUCM it has
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
which are the dtmf attributes for rtp-nte
Received:
INVITE sip:800123456@192.168.105.20:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.105.21:5060;branch=z9hG4bK1f9641bc9a8cc
From: "Marek JIRICEK" <13>;tag=136424~9c01f162-7d88-4d2e-927f-31024c52083a-27224612
To: <800123456>
Date: Mon, 08 Apr 2013 15:04:59 GMT
Call-ID: ad026500-1621dc9b-1f257-1569a8c0@192.168.105.21
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <192.168.105.21:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 2902615296-0000065536-0000000460-0359246016
P-Asserted-Identity: "Marek JIRICEK" <13>
Remote-Party-ID: "Marek JIRICEK" <13>;party=calling;screen=yes;privacy=off
Contact: <13>
Max-Forwards: 69
Content-Length: 337
v=0
o=CiscoSystemsCCM-SIP 136424 1 IN IP4 192.168.105.21
s=SIP Call
c=IN IP4 192.168.106.214
b=TIAS:64000
b=AS:64
t=0 0
m=audio 20790 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=ptime:20
a=rtpmap:18 G729/8000
a=ptime:20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
You should check the dial-peer that is matched for this call and ensure you have the proper dtmf type on it
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
12 Replies 12
Ayodeji Okanlawon
Please configure this..
dial-peer voice 3 voip
dtmf-relay rtp-nte sip-kpml
dial-peer voice 10 voip
test again..
Thanks for quick reply, but I've already tested more dtmf-relay setups in dial-peer. Now no change with that either, so post actual outputs isn't necessary.
M.
ok..please send
debug voip rtp session named-event
debug ccsip messages
RTP event from actually working 7940:
1w6d:          s=VoIP d=DSP payload 0x65 ssrc 0xE155D728 sequence 0x33E1 timestamp 0x1        FAC70
1w6d:  << Pt:101    Evt:1       Pkt:0A 00 00
1w6d:          s=DSP d=VoIP payload 0x65 ssrc 0xE155D728 sequence 0x33E1 timestamp 0x1        FAC70
1w6d:          Pt:101    Evt:1       Pkt:0A 00 00  >>
1w6d:          s=VoIP d=DSP payload 0x65 ssrc 0xE155D728 sequence 0x33E3 timestamp 0x1        FAC70
1w6d:  << Pt:101    Evt:1       Pkt:0A 00 A0
1w6d:          s=DSP d=VoIP payload 0x65 ssrc 0xE155D728 sequence 0x33E3 timestamp 0x1        FAC70
1w6d:          Pt:101    Evt:1       Pkt:0A 00 A0  >>
1w6d:          s=VoIP d=DSP payload 0x65 ssrc 0xE155D728 sequence 0x33E5 timestamp 0x1        FAC70
...and so on
SIP Messages attached.
Thanks a lot for helping
M.
Sent:
To: <800123456>
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 68
Content-Length: 197
v=0
s=SIP Call
t=0 0
a=ptime:20
a=fmtp:101 0-15
Received:
To: <800123456>
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Contact: <13>
Max-Forwards: 69
Content-Length: 337
v=0
s=SIP Call
b=TIAS:64000
b=AS:64
t=0 0
a=ptime:20
a=ptime:20
a=ptime:20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
I'll check it again, but when i debugged matching dial-peers last time, it was correct...see attach pls to find any mistakes.
Thank you
Please remove this command
no voice-class sip dtmf-relay force rtp-nte
Problem has been solved - matching for incoming dnis was different, to make it clear:
1w6d: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=3
1w6d: //-1/5131ED800000/DPM/dpAssociateIncomingPeerCore:
   Calling Number=13, Called Number=800123456, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=11
1w6d: //-1/5131ED800000/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=800123456, Peer Info Type=DIALPEER_INFO_SPEECH
I guess it happened because incoming-called command has higher priority than destination-pattern and it just matches that different dial-peer. If u have any ideas in this case, pls contact me. Otherwise I assume this config is working correctly.
Thanks a lot aokanlawon and others
With best regards
Mark
Marek..good to know its fine now..But you havent rated the correct post   and any other usefful post.It helps other
Nick Richards
Is that IOS release even supported with 8.6? The Release Notes seem to indicate otherwise:
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/UC8.6.1/release_notes/rnipt861.html
As always, whether it's supported and whether it actually works are two entirely different things...
NR
Well, that is always the question. But I dont think that is the correct way of looking on it. How do you explain all correctly working on 7940 with same setup?
M.
for outboumd DTMF issue , please try the below commands
 description **Outgoing Call to SIP Trunk**
 translation-profile outgoing PSTN_Outgoing
 destination-pattern ..............
 session protocol sipv2
 session target sip-server
 dtmf-relay rtp-nte
codec  g711ulaw
no vad !
Thank you
please rate if this weill help
