Dual Line ephone-dn roll over to Voicemail if both in use
I was wondering if it is possible for someone with an ephone-dn set as dual line to have a third call roll over to vmail if both are in use?
Any help is appreciated!
Thank you
7 Replies 7
Chris Deren
Sure, that would be the defaul behavior if you have voicemail configured.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevmail.html#wp1031671
HTH,
Chris
acampbell
Sean,
try putting hunt stop channel uner the ephone-dn
ephone-dn  2  dual-line
number 5002
pickup-group 1
call-forward busy 5990
call-forward noan 5990 timeout 15
huntstop channel
Alex
Regards, Alex. Please rate useful posts.
I do have voicemail configured and I do have huntstop on.
I also have it set to go to my vmail extension in the CFNA.
Sean,
So what are you hearing on the 3rd call?
Chris
3rd call is a busy signal
Can you post your full config?
What happens when you press the Messages button?
Chris
Right now I can't post the full config, but I will try to later.
When you press the messages button it all works as it should.
