02-22-2016 06:35 AM - edited 03-18-2019 11:49 AM
I've followed the (limited) DX80 manual instructions on supplying a Wallpaper for the DX80, but it's not working. The DX80 isn't using the wallpaper, nor is the wallpaper listed if you go into settings.
I've had a quick look at the console logs from the web interface, and I can't see anything obvious there.
GTG
02-22-2016 06:57 AM
Couple of things Gordon:
1) Please make sure that the image you are using there should strictly be 2985x1080 in size
2) Choose the path as Desktops/2985x1080x24
Edit to the O.P., refer to below defect and there is no need for List.xml file as you use for other phone models:
https://tools.cisco.com/bugsearch/bug/CSCut54061/?reffering_site=dumpcr
Deepak
02-22-2016 07:38 AM
1 - file is the correct size and colour depth:
uni_shield_1.png: PNG image data, 2985 x 1280, 8-bit/color RGBA, non-interlaced
2 - The file is in the (new) correct path:
3 - And it's specified on the device:
Doing a Wireshark, I can't see the DX80 making any TFTP requets. It only makes HTTP requests.
(Oh, and it's using the wrong NTP servers...)
Suggestions?
GTG
02-22-2016 07:46 AM
Did you try restarting the TFTP service on all the applicable servers Gordon.
Deepak
02-22-2016 07:51 AM
Yep:
$ tftp 172.18.0.35
tftp> get Desktops/2985x1080x24/uni_shield_1.png
Received 2471939 bytes in 2.9 seconds
GTG
02-22-2016 08:05 AM
Your image size is 2985 x 1280 that is correct as per the Documentation and once uploaded it should be resized to 2985 x 1080 on its own but can you upload the image itself as 2985 x 1080 and then try
Deepak
02-22-2016 08:05 AM
Er, do you mean to say upload a 2985 x 1080 image? If so, do I put it in the Desktops/2985x1080x24 directory instead?
GTG
02-22-2016 08:10 AM
That is correct, upload the image with the dimensions of 2985 x 1080 instead of 2985 x 1280 and put it in the Desktops/2985x1080x24 folder then.
Deepak
02-22-2016 08:27 AM
I've uploaded a 2985x1080x24 image into the Desktops/2985x1080x24 folder, reset the DX80 and....no joy :-(
GTG
03-02-2016 12:38 PM
Gordon - did you figure this out?
Dan
03-02-2016 01:50 PM
Currently have a TAC case open about this. TAC are confused. My wallpaper works on their DX80s, but not mine.
GTG
03-07-2016 04:40 AM
Solved the issue at last!
Despite the device having a setting for specifying the wallpaper, you can't set it on the device.
You have to use a common device profile. Set the wallpaper there, set the DX80 to use the profile and it works a treat.
<rant>Why would you offer a setting that doesn't work??</rant>
GTG
02-22-2016 08:17 AM
The observant will notice that I actually put the 2985x1280 file in the wrong directory. I've corrected that and still no joy.
My concern is that Wireshark is NOT showing any TFTP requests from the device. It only makes HTTP, and none of those are for the wallpaper.
GTG
07-05-2017 07:50 AM
Hi Gordon,
in the "Background Image" field, you should put only the name of the file (uni_shield_1.png) instead the full path
02-22-2016 02:18 PM
BTW - The details of BugID CSCut54061 has been updated to include what the correct path is.
GTG
