03-14-2012 09:25 AM - edited 03-16-2019 10:07 AM
Hi there,
I am configuring E1 controller and get the following error:
(config)#controller E1 0/2/0
(config-controller)# framing NO-CRC4
(config-controller)# line-termination 75-ohm
(config-controller)# ds0-group 0 timeslots 1-10 type r2-digital r2-compelled ani
(config-controller)# cas-custom 0
The channel must be a CAS channel
Would you know why I get that?
Thanks in advance for any hints and suggestions.
Rmei
03-14-2012 09:33 AM
However I managed to configure E1 this way:
controller E1 0/2/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-20 type r2-digital r2-compelled ani
cas-custom 1
category 2
answer-signal group-b 1
dnis-digits min 1 max 16
ani-digits min 0 max 16
ani-timeout 3
timer interdigit incoming 1000
groupa-callerid-end
trunk-group ALL_T1E1
What is the difference between ds0-group 1, cas-custom 1 and ds0-group 0, cas-custom 0 ?
Thanks.
03-14-2012 10:25 AM
Sometime numbering starts from 0, in this case it seems it must start from 1.
