02-16-2015 11:44 PM - edited 03-17-2019 02:00 AM
Hi all
is there a way, without using transformation patterns to translate an incoming E.164 number to 4 digit internal number
eg +32 1456 789 3123 to 2501
currently it is working using a transformation pattern on the trunk but using this method as soon as we partition the numbering plan incoming calls fail. The internal numbers are in <none>
Thanks in advance
Koen
Solved! Go to Solution.
02-17-2015 02:34 AM
Please remove the significant digit and configure xlation pattern to match the full pattern eg
Translation-pattern \+3214567893123
partition : select a partition that your sip trunk CSS has access to
CSS: Select a CSS that has access to the phone DN partition
called party transform mask: 2501
Ensure your sip trunk CSS can access the pt of the xlation pattern
02-17-2015 12:40 AM
Transformation pattern are used to change the number displayed on the phone once the call arrives.
I'm assuming that 2501 is an internal number, you can to this in the gateway or the trunk configuration page.
Call Routing Information - Inbound Calls:
02-17-2015 12:43 AM
thank you
that works but then it doesn't work when adding partitions
so in a way the problem lies now with partitions and CSS.... grrr
02-17-2015 12:49 AM
For example:
Parition: PT-Phones
Since the phones are now in a partition the GW cannot reach the phones without a CSS that contains the above PT:
CSS:
CSS-Gateway: ---> PT-Phones
If you assign this CSS to the GW then calls will work.
en calls will work
Call Routing Information - Inbound Calls: Significant Digits: 4 Calling Search Space: CSS-Gateway
02-17-2015 12:58 AM
this is what I have
PT_site -> phones
PT_system -> route patterns
PT_site_emergency -> specific emergency translation for that site
CSS_Site has all three PT's
as soon as I assign a phone in the PT_site the incoming calls fails, provider msg that there is no phone allocated
02-17-2015 01:17 AM
Ok,
Are you trying to translate 32 1456 789 3123 to 2501 --> if this is the case use the GW to translate the number to 2501
or
32 1456 789 2501 to 2501 ---> use the CUCM as shown above.
Go the Dialed Number Analyzer in Serviceability page, once there select:
Analysis -- > Gateway
Select on the Gateway
Calling Party: (Any number)
Called Party: 32 1456 789 2501
Any attached the output
02-17-2015 01:20 AM
here is the catch..... it is a SIP trunk directly on the CUCM no gateway involved, no CUBE due to budget restrains
02-17-2015 02:25 AM
This is very straight forward. You should use translation patterns not transformation pattern for this. Configure the pattern and select the CSS_site for the xlation pattern.
02-17-2015 02:29 AM
it doesn't work :(
trunk significant digits 6
translation pattern 123456 to 2000, PT_site, CSS_site
I am sure I am must be overlooking something
02-17-2015 02:34 AM
02-17-2015 02:44 AM
that worked
thank you all for the help
02-17-2015 02:46 AM
Glad to help. please mark the thread as answered
