04-25-2013 07:17 AM - edited 03-16-2019 04:59 PM
Hi Guys,
I,m trying to configure a 2801 router to act as a call processor in a network. Under ephone I'm looking for the 7942, 7962 and 7937 phone types but they do not appear. I've downloaded their respective firmware files but still no success.
The router is using an advanced enterprisek9-mz.124-25g IOS. Below is the running config. Any idea what the problem couold be?
version 12.4
hostname CATALYST_VG
boot-start-marker
boot-end-marker
enable secret 5 $1$q/8M$aMrYHel160Fe3TkqlMXQB1
no aaa new-model
no network-clock-participate wic 3
ip cef
no ip domain lookup
ip domain name catalystprincipal.com
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
isdn switch-type primary-net5
voice-card 0
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711alaw
codec preference 4 g711ulaw
voice translation-rule 1
rule 2 /^4296/ //
voice translation-profile INCOMING-E1
translate called 1
username catalyst secret 5 $1$e9pG$LQ4vOtFkkuIRnhWyha5W.1
controller E1 0/3/0
controller E1 0/3/1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
description CMS_VG INTERFACE FOR VOICE VLAN
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.20
description CMS_VG INTERFACE FOR DATA VLAN
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/1
ip address 192.168.30.1 255.255.255.0
duplex auto
speed auto
interface Serial0/2/0
no ip address
shutdown
clock rate 2000000
interface Serial0/2/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.20.254
ip route 192.168.30.3 255.255.255.255 192.168.10.254
ip dns server
ip http server
no ip http secure-server
ip http path flash:GUI
disable-eadi
tftp-server flash:XMLDefault.cnf.xml
tftp-server flash:SEPDEFAULT.cnf
tftp-server flash:apps42.9-3-1ES13.sbn
tftp-server flash:cnu42.9-3-1ES13.sbn
tftp-server flash:cvm42sccp.9-3-1ES13.sbn
tftp-server flash:dsp42.9-3-1ES13.sbn
tftp-server flash:jar42sccp.9-3-1ES13.sbn
tftp-server flash:SCCP42.9-3-1SR2-1S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:/term62.default.loads
tftp-server flash:/term42.default.loads
control-plane
sccp local FastEthernet0/0.10
sccp
sccp ccm group 1
bind interface FastEthernet0/0.10
associate profile 1 register conf_dsp_1
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 7
associate application SCCP
shutdown
dial-peer voice 500 voip
description "Voicemail Dialpeer"
destination-pattern 5..
session protocol sipv2
session target ipv4:192.168.10.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 100 pots
description "PSTN Dialpeer"
destination-pattern 9.T
incoming called-number 9T
direct-inward-dial
dial-peer voice 1 voip
description "Safaricom GSM Dialpeer"
destination-pattern 907[0-2].......
session target ipv4:192.168.30.3
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2 voip
description "Airtel GSM Dialpeer"
destination-pattern 907[3,8].......
dtmf-relay rtp-nte
codec g711ulaw
no vad
telephony-service
load 7960-7940 SCCP42
max-ephones 30
max-dn 150
ip source-address 192.168.10.1 port 2000
system message Catalyst Management Services
sdspfarm units 5
sdspfarm tag 1 conf_dsp_1
time-zone 31
date-format dd-mm-yy
create cnf-files version-stamp 7960 Apr 25 2013 16:54:15
voicemail 500
mwi relay
max-conferences 8 gain -6
moh music-on-hold.au
web admin system name cmsadmin password admin
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9.T
transfer-pattern ...
after-hours block pattern 1 9T 7-24
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
directory entry 1 000 name Reception
directory entry 2 001 name Paul Kavuma
directory entry 3 002 name Biniam Yohannes
directory entry 4 003 name Rajal Upadhyaya
directory entry 5 004 name Marlene Ngoyi
directory entry 6 005 name Vaishal Shah
directory entry 7 006 name Rosemary Ngure
directory entry 8 007 name Nixon Muthangya
directory entry 9 008 name Nyawira Gitau
directory entry 10 009 name Stephen Macharia
directory entry 12 011 name Bernard Ouma
directory entry 13 030 name Main Boardroom
directory entry 14 016 name Server Room
directory entry 15 020 name Vincent Rague
directory entry 16 021 name Seeta Shah
directory entry 17 030 name Main Boardroom
directory entry 18 031 name Meeting Room
directory entry 19 032 name Cubby Hole
directory entry 11 010 name Martha Osier
ephone-template 1
softkeys idle Redial Newcall Cfwdall Dnd
softkeys alerting Callback Endcall
softkeys connected Hold Trnsfer Endcall Confrn
ephone-template 2
softkeys idle Redial Newcall Cfwdall Dnd Pickup
softkeys connected Hold Endcall Trnsfer Confrn
ephone-template 3
ephone-dn 1 dual-line
number 000
pickup-group 10
label Reception - 000
description Reception
name Reception
ephone-dn 2 dual-line
number 001
pickup-group 10
label Paul Kavuma - 001
description Paul Kavuma
name Paul Kavuma
ephone-dn 3 dual-line
number 002
pickup-group 10
label Biniam Yohannes - 002
description Biniam Yohannes
ephone-dn 4 dual-line
number 003
pickup-group 10
label Rajal Upadhyaya - 003
description Rajal Upadhyaya
ephone-dn 5 dual-line
number 004
pickup-group 10
label Marlene Ngoyi - 004
description Marlene Ngoyi
name Marlene Ngoyi
ephone-dn 6 dual-line
number 005
pickup-group 10
label Vaishal Shah - 005
description Vaishal Shah
name Vaishal Shah
ephone-dn 7 dual-line
number 006
pickup-group 10
label Rosemary Ngure - 006
description Rosemary Ngure
name Rosemary Ngure
ephone-dn 8 dual-line
number 007
pickup-group 10
label Nixon Muthangya - 007
description Nixon Muthangya
ephone-dn 9 dual-line
number 008
pickup-group 10
label Nyawira Gitau - 008
description Nyawira Gitau
name Nyawira Gitau
ephone-dn 10 dual-line
number 009
pickup-group 10
label Stephen Macharia - 009
description Stephen Macharia
ephone-dn 11 dual-line
number 011
pickup-group 10
label Bernard Ouma - 011
description Bernard Ouma
name Bernard Ouma
ephone-dn 12 dual-line
number 022
pickup-group 10
ephone-dn 13 dual-line
number 020
pickup-group 10
label Vincent Rague - 020
description Vincent Rague
name Vincent Rague
ephone-dn 14 dual-line
number 102
pickup-group 10
label Meeting Room - 102
description Meeting Room
name Meeting Room
ephone-dn 15 dual-line
number 010
pickup-group 10
label Martha Osier - 010
description Martha Osier
name Martha Osier
ephone-dn 16 dual-line
number 021
pickup-group 10
label Seeta Shah - 021
description Seeta Shah
name Seeta Shah
ephone-dn 18 dual-line
number 023
pickup-group 10
label Guest - 023
description Guest
name Guest
ephone-dn 19 dual-line
number 105
label Security Desk - 105
description Security Desk
name Security Desk
ephone-dn 20 dual-line
number 103
label Cubby Hole - 103
description Cubby Hole
name Cubby Hole
ephone-dn 21 dual-line
number 101
label Main Boardroom - 101
description Main Boardroom
name Main Boardroom
ephone-dn 22
number 501..
mwi on
ephone-dn 23
number 205
description Meet-Me Conference Number
preference 2
no huntstop
mwi off
ephone-dn 30 dual-line
number A000
description Ad-Hoc Conference Number
no huntstop
ephone-dn 31 dual-line
number A000
preference 1
no huntstop
ephone-dn 32 dual-line
number A000
ephone 1
ephone 4
ephone-template 2
mac-address A418.758A.2F76
button 1:4
ephone 5
ephone-template 2
mac-address A418.7529.8386
button 1:5
ephone 6
ephone-template 2
mac-address A418.7529.8441
button 1:6
ephone 7
ephone-template 2
mac-address A418.7529.8450
button 1:7
ephone 8
ephone-template 2
mac-address A418.7529.83AC
button 1:8
ephone 9
ephone-template 2
mac-address A418.7529.8462
button 1:9
ephone 10
ephone-template 2
mac-address F4EA.6749.B07D
button 1:15
ephone 16
ephone-template 2
mac-address A418.7529.81F5
button 1:16
ephone 18
ephone-template 2
mac-address A418.7529.821D
button 1:18
ephone 19
ephone-template 2
mac-address A418.7529.84D5
button 1:19
ephone 20
ephone-template 3
mac-address 0004.F2F0.588E
button 1:21
ephone 21
ephone-template 3
mac-address 0004.F2F0.56C4
button 1:20
04-25-2013 07:29 AM
I don't have the answer but I did just double check the IOS version which is required to support these phones:
Q. What Cisco Unified Communications Manager Express release is required for the phones?
A. The Cisco Unified IP Phone 7962G and Cisco Unified IP Phone 7942G are first supported by Cisco Unified Communications Manager Express Version 4.1 and Cisco IOS Software Release 12.4(15)T (available now).
Additionally, I looked at the ephone-type command usage, as this command allows you to create/define models not already available to you.
"This configuration template defines a set of attributes that describe the features of the new phone type. Use this command to add phone types that are not already defined in the system."
Source: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_e1ht.html#wp1074542
But I don't think you should need the ephone-type command, as the above IOS version check confirms it should already be there. Like I said, not the answer, just trying to help a bit. Good luck and I'll be following this thread to see where it goes.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
04-25-2013 07:44 AM
Andrew-
I believe that you may need to go to a different IOS version, something like 12.4(24)T. As you can see in this link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
The version of code that you are mentioning is not on that list, in fact there are no G versions of code on there. The 12.4(24)T version is on there and the documentation for the 7.1 version of CME says that it will support the 7942 and 7962 phones.
Hope that helps.
04-25-2013 07:53 AM
Thanks John and Antony. Let me change the IOS and see what happens
04-25-2013 08:08 AM
Hi Guys,
I upgraded to a c2801-advipservicesk9-mz.124-15.T13.bin and now the router is constantly rebooting and i get the followinf error repeatedly:
"Possible Software Fault.Upon recurrence.please collect crashinfo, "show tech" and contact cisco Technical Support".
04-25-2013 08:25 AM
Andrew,
Is the reboot continuous or do you have a few moments once the router boots up to enter some commands? If it's continuous, you might need to go into ROMMON and change the firmware again or collect diagnostic information if your heart is set on that version.
04-25-2013 08:29 AM
The reboot is continous. I do not get a chance to enter any command.
How can I change the firmware to support the newer IOS's and also how do I get the diagnostics from ROMMON mode.
04-25-2013 08:37 AM
Hi Andrew,
Press Ctrl + Break to enter into ROMMON mode.
Use tftpdnld command to upload IOS.
Use the procedure as described in URL
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon.html
regds,
aman
04-25-2013 08:51 AM
Thanks Aman,
I had already done that and had restored the old IOS that did not support the ephone types.
It seems whenever I put a higher end IOS I get the recurring error. Which IOS will support the 7942, 7962 and 7937 phones and not crash on this router? Below is the show version for the router:
Cisco IOS Software, 2801 Software (C2801-ADVENTERPRISEK9-M), Version 12.4(25g), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 22-Aug-12 05:32 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
CATALYST_VG uptime is 19 minutes
System returned to ROM by error - a Software forced crash, PC 0x605F96FC at 15:24:29 UTC Thu Apr 25 2013
System image file is "flash:c2801-adventerprisek9-mz.124-25g.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2801 (revision 5.0) with 116736K/14336K bytes of memory.
Processor board ID FCZ092513EU
2 FastEthernet interfaces
33 Serial interfaces
2 Serial(sync/async) interfaces
2 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
5 DSPs, 72 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
04-25-2013 08:53 AM
Can you also send output for:
show telephony
04-26-2013 12:24 AM
Hi John,
Below is the output of show telephony
CATALYST_VG#show telephony-service
CONFIG (Version=3.3)
Version 3.3
Cisco CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
max-ephones 30
max-dn 150
dspfarm units 5
dspfarm transcode sessions 0
dspfarm 1 conf_dsp_1
dspfarm 2
dspfarm 3
dspfarm 4
dspfarm 5
hunt-group report delay 1 hours
max-redirect 5
voicemail 500
mwi relay
time-format 12
timezone 31 Saudi Arabia Standard Time
keepalive 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
caller-id name-only: enable
web admin customer name Customer
edit DN through Web: enabled.
edit TIME through web: enabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Apr 26 2013 10:26:11
local directory service: enabled.
04-26-2013 01:20 AM
Hi Andrew,
the CME version 3.3 which u are using does not show support for 7942/7962 IP phones in compatibility matrix.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme33spc.html
regds,
aman
04-26-2013 02:27 AM
Hi Aman,
Thanks. Where do I get the CME files to upgrade to the router.
04-26-2013 03:13 AM
Hi Andrew,
You can use the link for downloading but u also need to change CME version.
http://software.cisco.com/download/type.html?mdfid=277641082&catid=null
regds,
aman
04-26-2013 03:15 AM
How do I change the CME version. I thought after installing the new version telephony-service will automatically be updated.
