09-19-2007 12:45 PM - edited 03-14-2019 11:37 PM
I have a 2801 Router that gets the following error when I try to manually bring up mgcp:
Sep 19 20:36:04.753: ISDN Se0/1/0:23 **ERROR**: L2IF_SendPkt: idb is NULL
Sep 19 20:36:04.753: ISDN Se0/1/0:23 **ERROR**: L2IF_SendprimPkt: L2IF_SendPkt failed
Has anyone seen this before?
09-20-2007 10:30 AM
Hi Tom,
have you performed the Hard Loop Test to rule out hardware failure of the VWIC
Make sure no ACL are blocking MGCP traffic
and the following is configured.
interface serial0/1/0:23
isdn bind-l3 ccm-manager
09-21-2007 05:28 AM
I had not performed any loop tests (I have been lucky w/new hardware so that's generally the last thing I suspect). There are no alarms of any kind and the d-channel is up. The only difference in this site and my others is that the PRI is fractional (only 5 channels). I know 4.1(3) & MGCP do not 'support' this configuration and that may be the crux of my problem. I was expecting a different kind of error.
11-17-2015 06:42 PM
[+5] to you.
I came across this issue and entering the isdn bind-l3 ccm-manager under serial interface resolved the issue.
regds,
aman
09-14-2019 10:17 AM
01-25-2021 04:57 PM
5.5 years later and this post just saved me. I was changing a full PRI to a partial PRI.
I had to issue the command: no pri-group timeslots 1-24 service mgcp.
Then I re-added the command: pri-group timeslots 1-12,24 service mgcp
Apparently when I did this, it removed the: isdn bind-l3 ccm-manager command from the serial interface without my knowledge.
The T1 controller showed Up.
The Serial 0/1/0:23 interface showed Up.
CUCM showed the gateway as registered.
But the gateway would not process calls and I started seeing the errors show in the original post.
Fortunately a Google search of the error messages lead me to this post with the solution!
