06-20-2007 10:43 AM - edited 03-14-2019 10:11 PM
A great number of my phones are cutting off , disconnecting calls. This happens a couple times a day. I am recieved the following error.
Error: DeviceUnregistered - Device unregistered.
Device name.: SEP0017E0D8147B
Device IP address.: 172.29.24.30
Device type. [Optional]: 309
Device description [Optional].: Patrick Alton
Reason Code [Optional].: 8
App ID: Cisco CallManager
Cluster ID: StandAloneCluster
Node ID: 172.29.12.253
Explanation: A device that has previously registered with Cisco CallManager has unregistered. This event may be issued as part of normal unregistration event or due to some other reason such as loss of keepalives.
Recommended Action: No action is required if unregistration of this device was expected..
Any help is appreciated.
Fred Beebe
06-26-2007 10:16 AM
Reason Code 8 means device initiated reset. This usually happens when there is a connectivity problem on your network between the devices and the CM servers or when the CM server is too busy to reply to keepalives. In both cases, the problem is due to missed keepalives between the devices and the CM servers. The reason why you may be seeing the errors
on both servers is because the devices may be rehoming between Pub and Sub when unregistering, which is normal fallback behavior when connectivity is lost to the current CM server.
06-28-2007 11:15 AM
I'm running into the same issue with a device. I'm not sure if it's a cabling issue or not. The switch is reporting no errors. Does anyone know how to adjust the keepalive timeout? Tx
07-30-2007 12:12 PM
I'm having the same issue
One thing that we have been noticing when this happens, is multiple phones in the are are going down. After close inspection, the switch is not going down, but the gig port is.
No other phones at the location are (we have 300+ at this location), just the 4 phones at this switch.
Could this possibly be spyware on the computer freaking the switch out?
Device name.: SEP000C307087B2
Device IP address.: 10.111.1.40
Device type. [Optional]: 8
Cluster ID: SJCCALLMGR1-Cluster
Node ID: 10.11.0.7
06-07-2012 08:18 AM
hi
We are using Call Manager 8.5.1 SU4 and IP Communicator 8.6.1.13 we are facing this issue at very high frequency . anyone solved this issue
Irfan Tariq
12-19-2012 12:38 PM
All -
Any resolution to this issue?
TIA,
Amir
12-19-2012 01:05 PM
Wow - resurrecting a really old thread. As pointed out, this error typically indicates a network issue or congestion preventing timely acks to phone keepalives. The resolution is to find and correct the root cause. That said, a workaround would be adjusting the keepalive threshholds to prevent the phone from re-registering. The down side is that on an actual failure/loss of connectivity, the phones will take longer to recover.
These are both callmanager service parameters:
11-01-2017 09:43 AM
Hello 5 years later.
So we have an Expressway User working at home in San Jose and when he puts an external caller on hold to transfer him the phone resets.
|AppInfo |<--RISCMAccess::DeviceUnRegister(...)
|AppInfo |SIPStationD(4599) - shutdownDevice: dropping call,
|AppInfo |SIPStationD(4599) - retryRegister: recycling
This happens every time and ever since we enabled call recording. Any ideas on how to get this to stop so we can keep call recording?
