Error encountered: The selected file is not valid. Please ensure that the COP/ISO file is intended for this release. MD5 Hash Value: 74:75:1f:51:68:7a:7f:6a:11:6e:92:84:6b:1a:dd:c0
oscar cordero
Short description:
I can not install cop firmware phone 9.3(4)  (cmterm-8941_8945-sccp.9-3-4-17.cop.sgn) on CUCM 11(0)1.
During SFTP installing I got error :
If I try to install version 9.4(2)SR2, I have not errors.
File 9.3(4) is not corrupt.
Conclusion with 9.3(4) is not possible but with 9.4(2)SR2 yes.
Long description:
we are trying to register the phone CP-8945. this 8945 currently have version SCCP 9-1-2-00.
CUCM 11(0)1 have preload version 9.4(2)SR1.
on release notes for 9.4(2)SR1 said: Release 9.4(2)SR1 can only be upgraded from 9.3(4) and later. Releases prior to 9.3(4) have to be upgraded to 9.3(4) first.
6 Replies 6
Rob Huffman
Hi Oscar,
I know why the 9-3-4 file is not working with the CUCM 11.0.1 version (as shown below);
To improve software integrity protection, new public keys are used to sign cop files for Cisco Unified Communications Manager Release 10.0.1 and later. These cop files have "k3" in their name. To install a k3 cop file on a pre-10.0.1 Cisco Unified Communications Manager, consult the README for the ciscocm.version3-keys.cop.sgn to determine if this additional cop file must first be installed on your specific Cisco Unified Communications Manager version. If these keys are not present and are required, you will see the error "The selected file is not valid" when you try to install the software package.
From;
http://www.cisco.com/web/software/282074289/128819/cmterm-894x-sccp.9-4-2SR2-2-readme.html
The 9-3-4  firmware file which is available for download does not have the "k3" which would be required for use in the new 11.0.1 CUCM version. You would need to contact TAC to secure the proper firmware files.
Cheers!
Rob
[+5] to Rob for sharing the info.
I can see that  k3 is available in 9.4(2) SR2 but not in 9.3(4) .
cmterm-894x-sip.9-4-2SR2-2.k3.cop.sgn
Same for SCCP also.
You need to open case with TAC for resolution and share the outcome.
regds,
aman
I have the same issue .
Did you resolve it ?
Guillaume, look at below thread wherein customer face exactly the same issue:
https://supportforums.cisco.com/discussion/12929151/cucm-110-cannot-upload-firmware-error-encountered-md5-issue
Deepak
That's weird, the old keys should still be available on CUCM 10.x+, and also the new keys, that should be no problem.
java
if this helps, please rate
Amit Sharawat
Looks like we are hitting the defect : CSCuv73972
Please follow the workaround mentioned in the defect and check if we are able to install it.
~Amit
