explanation required for following config
techguy
Level 4
Level 4
voice translation-rule 1
rule 1 /^/ /0/
voice translation-rule 2
rule 1 /^/ /00/
voice translation-rule 3
rule 1 /^/ /000/
voice translation-rule 4
rule 1 /^/ /0000/
voice translation-rule 5
rule 1 /^786320\(...\)/ /1\1/
voice translation-profile incoming
translate called 5
voice translation-profile srst_6132473
translate called 3
voice translation-profile srst_6136233
translate called 2
voice translation-profile srst_6315799
translate called 4
voice translation-profile srst_6320940
translate called 1
voice-port 0/0/0
translation-profile incoming incoming
compand-type a-law
bearer-cap Speech
dial-peer voice 7 pots
translation-profile incoming srst_6320940
answer-address 6320940
dial-peer voice 8 pots
translation-profile incoming srst_6136233
answer-address 6136233
dial-peer voice 9 pots
translation-profile incoming srst_6132473
answer-address 6132473
dial-peer voice 10 pots
translation-profile incoming srst_6315799
answer-address 6315799
Chris Deren
It basically prefixes different digits to called number based on where the call is coming from.
As to why 0, vs. 00 vs. 000 is prefixed you would need to ask the person who designed it, perhaps it was meant to tag the call differently for further routing.
Chris
Ayodeji Okanlawon
Omerpal,
You need to do some study. I am afraid thats the only way you will learn...
Here is an excellent documentation on understanding translation rules...
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
If you have any question after reading it then feel free to ask. I am sure once you read the doc you will understand those configurations
Pls rate useful posts
Please rate all useful posts
Answer address is used for incoming dialpeers ( both incoming and outgoing ). It makes decision based on
ANI (Calling number) output.
