Extension Mobility disable 'change PIN'
tdudas
Hi All,
I have CUCM 8.0.3 configured with Extension Mobility. The issue I'm facing with: when user tries to log in, user asked for 'change PIN'. I have set PINs via BAT for all the users and that need to be used. How can I disable it?
Thanks!
Tibor
2 Accepted Solutions
Chris Deren
Adjust the policy not to require change on first login.
Ayodeji Okanlawon
Tdudas,
You can use cucm user credential policy to do this..
NB: You will need to delete the users first and re-add them using this new credential policy. The reason is because when a user is added in cucm, it uses the default credential policy to apply the user related configs such as wether to change pin at login or not.
So do the ff: CUCM admin, user management>credential policy default>default credential polcicy (select the one for end user and PIN)
Untick user must change at next login. Then click save.
Now re-add the users. They will inherit this new credential policy and you wont see change PIN on login..
Please rate useful posts
Please rate all useful posts
7 Replies 7
Chris Deren
Hi Chris,
Yep, just tried without success.
with BAT I could uncheck '', but only if you reset the PIN as well.
next step was to set the required PIN via BAT Update Users. After job finished and checked a user, this checkbox was checked again.
I might do something wrong or I found a bug?
Thanks!
Tibor
Thank you Chris!
Tibor
Ayodeji Okanlawon
Tdudas,
Hi aokanlawon,
Thanks for your answer!
CUCM has LDAP integration, I can not delete them easily, although I tried the following:
I do not really understand why?????
Unfortunately the authenticaton rule has no affect on this checkbox (pls see image attached)
Thanks!
Tibor
Unfortunately once a user has been imported into cucm with a credential policy it inherits that policy. Unless you delete the user and re-add them there  is no way it will loose that policy from experience..
With AD integration, you need to disable Ldap system, then delete the users...If you used BAT to add device profiles etc, you should be able to BAT them easily back after deleting them.
You will them re-enable LDAP  and then re-sycn the LDAP with AD. The users will come back and will inherit the new credential policy you have set.
OKAY!!!
You are right!
(I did not need to delete users, just unchecked this box:
user management > Credential Policy Defaults > Credential Policy Defaults for PIN
uncheck ''
then BAT > Update Users with the required PINs
Thanks!
