05-15-2013 11:25 PM - edited 03-16-2019 05:20 PM
Dear All,
I am running call manager 9.1.
I need to apply a policy in such a way that for example:
If any user who dials any mobile number or international number he should be prompted to ask for the pin or security code.
Please guide me the best way to accomplish this task.
I will be very thankful for your support.
Malik
Solved! Go to Solution.
05-16-2013 03:27 AM
Hi Malik,
You can do this by creating two different Route patterns as already done and assigning them in different partitions. Similarly, assigning these different partitions to two different users.
Since FAC codes are unique, then, user cannot dial unless they are shared.
Like Route pattern 1 assigned in Partion 1 . User 1 assigned in CSS1 consisting of Parttion 1 .Dials by pressing 8.mobile number
Similarly for user 2 ---CSS2---Partition2 and Route Pattern 2 in parttion2 .Dials by pressing 9.mobile number
regds,
aman
05-16-2013 06:48 AM
CUCM has no idea which user needs to dial a code or not, it only know is shouls ask for FAC/CMC to whoever tries to call via a RP that has either/both checkboxes checked.
So, if you don't want to do this for all users, you'll need two separate route patterns as Aman explained.
This is also explained in the very first document that was provided:
Now since we have 3 users configured with Forced Authorization Codes, we will now proceed to modify
and place a restriction in our route patterns so that when a User dials a certain string of numbers
matching a certain route pattern configured to require a Force Authorization Code/Authorization Level
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-19-2013 04:27 AM
Hi Malik,
Please refer the links for EM configuration.
http://www.voicecerts.com/2010/06/step-by-step-guide-to-configuring.html
regds,
aman
06-05-2013 02:43 AM
Hi Malik,
You wont' be able to do since u are selecting the Phone model while configuring device profile.
regds,
aman
05-15-2013 11:56 PM
Hi Malik,
You can go for FAC . The same needs to be applied to Route Patterns[in your case, mobile or international number]
Refer this link for FAC config.
regds,
aman
05-16-2013 12:48 AM
Hi Aman,
thanks a lot for your response. i really appreciate.
the think is that i need a policy in such a way that each user should be promoted for code but i have to assign a different code for each user.
For example each user should have his own force authentication code
Please let me know if you have any question so i can explain better.
Malik.
05-16-2013 12:56 AM
Hi Malik,
Please look into this URL where similar question was asked.
https://supportforums.cisco.com/message/3925842#3925842
regds,
aman
05-16-2013 01:22 AM
Hi Aman,
thank for your reply i have gone through the post.
Lets summarize it.
For example i have two users with mobile access .
I will check mark the option in route pattern for the mobile partition with authorization code 1
but i need to know how i can assign different code for individual user.
Malik.
05-16-2013 01:31 AM
Hi Malik,
You need to create for each user.
If u refer the link I have send on page 3, u can find there.
regds,
aman
05-16-2013 03:16 AM
Hi Aman,
I do understand this thing.
I assigned two different users with two different codes for mobile dialing.
But my question is that how come the call manger knows that this user should dial this code.
I tested in the same way you informed in the document but both the users can use each other codes to dial mobile.
Please gudie me how i can fix this issue.
Malik.
05-16-2013 03:27 AM
Hi Malik,
regds,
aman
05-16-2013 06:48 AM
java
05-19-2013 03:42 AM
Thanks Jaime
05-17-2013 06:40 AM
If your objective is to monitor people making international and nation calls, why cant you use Extension mobility service and use CDR report to pull out the information.
05-19-2013 03:43 AM
thanks dojoy
please you please guide me how i can enable/configure ext mobility
Malik
05-19-2013 04:27 AM
Hi Malik,
regds,
aman
05-29-2013 12:41 AM
Hi Aman,
It is such a great document that i cant thank in words.
Thanks for your amazing support.
Malik.
05-29-2013 03:23 AM
Hi Aman,
I have configured all the steps menstioned in the doc
but still when i press the services button on the ip pohne it says no service configured.
Any idea what could be the issue.
Malik.
