IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5824 Views
  • 14 replies
this is a problem related to mva i hav a h323  gateway configured with an mva application with incoming dial-peers when i dial the mva number from pstn it asks for the pin number when i try to forward the call to a numberthe call gets disconnected in...
HiWe are facing a problem with CUCM 8.0(3) and 8.6(2a) when a remote destination calls in from an H.323 gateway to a busy IP phone. The mobile phone with the remote destination number just gets a ringback tone (Q.931 Alerting) as if the IP phone woul...
Hi,I have calls coming into my cluster in E164 format, whilst retaining 7 digit internal extension numbers. I have two clusters setup using a non-Gatekeeper controlled inter cluster trunk, the issue I have is the + not being sent across the ICT, for ...
ian.ryder by Level 1
  • 1403 Views
  • 5 replies
