Find out what users have no "Primary Extension"
kylebrogers
Level 4
Level 4
Is there a way to determine what users on a system have no Primary Extension set?  There isn't a Primary Extension field in the search criteria of the End Users page.
This is CUCM 8.6.2.
slashdots
I don't know any pre defined report for that.
If your familiar with the CUCMs CLI you can run an SQL query to get this.
I’ve played around a little bit and created this query:
run sql select userid from enduser
where userid NOT IN
(select u.userid from enduser as u
inner join endusernumplanmap as nm on u.pkid=nm.fkenduser
inner join numplan as n on nm.fknumplan=n.pkid)
Be careful when playing around with SQL queries, always keep an eye on CPU and memory usage of CUCM.
hope that helps
it's long ago that you have posted your question, here is the answer if you still need it:
The easiest way I found is to export the users to the txt file then import to Excell - there you can easily see it.
Go:  Bulk Administration > Users > Export Users,  export in format "All User Format"
Cheers,
