11-12-2012 11:00 AM - edited 03-16-2019 02:08 PM
Is there a way to determine what users on a system have no Primary Extension set? There isn't a Primary Extension field in the search criteria of the End Users page.
This is CUCM 8.6.2.
11-13-2012 04:36 AM
I don't know any pre defined report for that.
If your familiar with the CUCMs CLI you can run an SQL query to get this.
I’ve played around a little bit and created this query:
run sql select userid from enduser
where userid NOT IN
(select u.userid from enduser as u
inner join endusernumplanmap as nm on u.pkid=nm.fkenduser
inner join numplan as n on nm.fknumplan=n.pkid)
Be careful when playing around with SQL queries, always keep an eye on CPU and memory usage of CUCM.
hope that helps
03-07-2014 05:37 AM
it's long ago that you have posted your question, here is the answer if you still need it:
The easiest way I found is to export the users to the txt file then import to Excell - there you can easily see it.
Go: Bulk Administration > Users > Export Users, export in format "All User Format"
Cheers,
