forward incoming calls (on specific E1 number) to external mobile phone number
chawkideeb
Dears,
we have voice gateway with E1.
Can you send us the detailed step by step configuration for the below scenario :
Customers (from outside the company) should call 07713454545 (specific E1 Number on voice gateway), so the voice gateway should redirect the calls to a normal mobile Asia cell number (07706721119).
Thank you,
best regards,
If you want to make this completely separate from existing config:
voice translation-rule 100
rule 1 /^07713454545$/ /07706721119/
voice translation-profile HAIRPIN
translate called 100
dial-peer voice 100 pots
translation-profile incoming HAIRPIN
incoming called-number 07713454545$
direct-inward-dial
You don't need a separate outbound dial-peer for 07706721119. The assumption is that it would match an existing outbound dial-peer that points to port 1/1:15. If the destination-pattern in that dial-peer has 9 in front, then add 9 in rule 1.
7 Replies 7
balaji.bandi
Not sure what you using ( you need to mention your environment details, so best suggest can be provided)
but in general call forward :
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmetrans.html
http://www.ciscopress.com/articles/article.asp?p=401648&seqNum=9
BB
Dear Balaji,
All that i have is a voice E1 that is connected to a voice gateway and the voice gateway to a call manager 11.x
E1>VG>CUCM.
the E1 is used for incoming calls from PSTN and outgoing call to PSTN.
And as you know , that E1 has a range of numbers that you can use it (0771345XXXX). in our case the number that is used for incoming calls is 07713454545.
what i need exactly is only on the voice gateway level configuration in the way that :
when customer call 07713454545 , the call should not be transfered to an internal extention or to an IVR.it should be redirected to a PSTN Mobile phone number ( asiacell number (07706721119)).
Thank you.
You could create another dial peer with 'incoming called-number 07713454545'. Then apply an inbound translation profile to it that translates it to the target number. Or keep using the same dial-peer and just add the translation.
The E1 provider may reject the call if it doesn't recognize the calling number. So, you may either have to add a valid Redirecting Number or mask the calling number entirely.
Dear Evgeny,
this is exactly what i am searching for it.
can you send me plz the exact command and config (i already shared all the necessary numbers).
thank you
Dears,
This is what i used , but it is not working :
voice translation-rule 3454545
rule 1 /^.*/ /07713454545/
rule 2 // /07713454545/
rule 3 /.*/ /07713454545/
dial-peer voice 6721119 pots
destination-pattern 907706721119$
translate-outgoing calling 3454545
port 1/1:15
forward-digits 11
direct-inward-dial
