07-03-2012 01:54 PM - edited 03-16-2019 11:59 AM
Hi All,
I am having issues to convert my current voice system to pure VOIP. There is the deal, currently we have a T1 link coming from our Telco to the current PBX(TELECO ----> PBX). This works fine.
Now, want to replace the legacy PBX with an Asterisk server but asterisk server does not have a T1 card yet. The goal is to used cisco router with a T1 card, and forward the calls to the asterisk server. So new design needs to be TELCO ------> Cisco router-------> Aterisk server.
With the T1 connected to the cisco router, i can't call out nor i can't receive calls from the PSTN.
Debug out from the asterisk server show: "Got SIP response 503 "Service Unavailable" back from 10.1xx.0.x(cisco router with the T1 card)"
Below are show outputs taken from the cisco router:
sh controllers t1
T1 0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20090113, FPGA: 20, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (542 seconds elapsed):
56 Line Code Violations, 632 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 334 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
sh isdn status
Global ISDN Switchtype = primary-5ess
ISDN Serial0/0:23 interface
dsl 0, interface ISDN Switchtype = primary-5ess
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 1
Total Allocated ISDN CCBs = 0
Partial router configuartion:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
voice class codec 1
codec preference 2 g711ulaw
codec preference 3 g711alaw
controller T1 0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface Serial0/0:23
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-5ess
isdn incoming-voice voice
no cdp enable
voice-port 0/0:23
echo-cancel coverage 32
timeouts interdigit 2
dial-peer voice 3001 pots
destination-pattern .T
direct-inward-dial
port 0/0:23
dial-peer voice 45 voip
description -- SEND CALLS TO PBX
preference 1
destination-pattern 123456789$
voice-class codec 1
session protocol sipv2
session target ipv4:5.5.5.5(PBX IPS)
dtmf-relay rtp-nte
ip qos dscp cs5 media
no vad
dial-peer voice 36 pots
incoming called-number 123456789
direct-inward-dial
Any helps or suggestion will be greatly appreciate,
Ernest
07-03-2012 03:17 PM
Please post debug isdn q931 and debug ccsip messages.
What version iOS are you using?
07-03-2012 04:18 PM
Debugs output to follow...
#sh ver
Cisco IOS Software, C1700 Software (C1700-IPVOICEK9-M), Version 12.4(15)T11, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 29-Oct-09 08:41 by prod_rel_team
ROM: System Bootstrap, Version 12.2(4r)XL, RELEASE SOFTWARE (fc1)
uptime is 2 weeks, 3 hours, 3 minutes
System image file is "flash:c1700-ipvoicek9-mz.124-15.T11.bin"
Thanks for the help,
Ernest
07-04-2012 09:02 AM
Ernest,
I do not see any debugs only "sh ver" output.
Chris
09-07-2012 08:34 AM
Hi Guys,
I know that this discussion has been 'quiet for a while',you know it is summer time. Got to enjoy the weather.
Anyway, the currecnt issue is that setup (PBX ---> CISCO H323 ---> Telco).
OUTBOUND calls from phone register to the BPX work fine, but inbound from the PSTN died at the H323 router, even on analog phone connected to fxs port... But at the initial setup, the inbound calls worked let's say about 3 weeks ago!!
keep getting: Cause i = 0x80E262 - Message not compatible with call state or not implemented. For calls going to phone behind the PBX and Cause i = 0x82E0 - Mandatory information element missing. For calls going to FXS port, i can see the port picks up the call, but the phone never rings
1/0 - - - FXSLS_ONHOOK
1/1 g711ulaw y S_SETUP_REQ_PROC FXSLS_WAIT_OFFHOOK
Below is debug ISDN
Thu Sep 06 18:22:04 2012: <191>9411: Calling Party Number i = 0x2181, '4xx36xxxxx'
Thu Sep 06 18:22:04 2012: <191>9412: Plan:ISDN, Type:National
Thu Sep 06 18:22:04 2012: <191>9413: Called Party Number i = 0xA1, '4xx34xxxxx'
Thu Sep 06 18:22:04 2012: <191>9414: Plan:ISDN, Type:National
Thu Sep 06 18:22:04 2012: <191>9415: Sep 7 00:22:03.928: ISDN Se0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8330
Thu Sep 06 18:22:04 2012: <191>9416: Channel ID i = 0xA9838B
Thu Sep 06 18:22:04 2012: <191>9417: Exclusive, Channel 11
Thu Sep 06 18:22:05 2012: <191>9418: Sep 7 00:22:03.960: ISDN Se0/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x0330
Thu Sep 06 18:22:05 2012: <191>9419: Facility i = 0x9F8B0100A1080201010201008400
Thu Sep 06 18:22:05 2012: <191>9420: Sep 7 00:22:03.968: ISDN Se0/0:23 **ERROR**: Ux_BadMsg: Invalid Message for call state 9, call id 0x11C, call ref 0x8330, event 0x62
Thu Sep 06 18:22:05 2012: <191>9421: Sep 7 00:22:03.968: ISDN Se0/0:23 Q931: TX -> STATUS pd = 8 callref = 0x8330
Thu Sep 06 18:22:05 2012: <191>9422: Cause i = 0x80E262 - Message not compatible with call state or not implemented
Thu Sep 06 18:22:05 2012: <191>9423: Call State i = 0x09
Thu Sep 06 18:22:15 2012: <191>9424: Sep 7 00:22:14.064: ISDN Se0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x0330
Thu Sep 06 18:22:15 2012: <191>9425: Cause i = 0x82E6 - Recovery on timer expiry
Thu Sep 06 18:22:15 2012: <191>9426: Sep 7 00:22:14.076: ISDN Se0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8330
Thu Sep 06 18:22:15 2012: <191>9427: Cause i = 0x80E2 - Message not compatible with call state or not implemented
Thu Sep 06 18:22:35 2012: <191>9428: Sep 7 00:22:34.470: ISDN Se0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0331
Thu Sep 06 18:22:35 2012: <191>9429: Bearer Capability i = 0x8090A2
Thu Sep 06 18:22:35 2012: <191>9430: Standard = CCITT
Thu Sep 06 18:22:35 2012: <191>9431: Transfer Capability = Speech
Thu Sep 06 18:22:35 2012: <191>9432: Transfer Mode = Circuit
Thu Sep 06 18:22:35 2012: <191>9433: Transfer Rate = 64 kbit/s
Thu Sep 06 18:22:35 2012: <191>9434: Channel ID i = 0xA9838E
Thu Sep 06 18:22:35 2012: <191>9435: Exclusive, Channel 14
Thu Sep 06 18:22:35 2012: <191>9436: Facility i = 0x9F8B0100A10F020101020100800750524956415445
Thu Sep 06 18:22:35 2012: <191>9437: Progress Ind i = 0x8283 - Origination address is non-ISDN
Thu Sep 06 18:22:35 2012: <191>9438: Calling Party Number i = 0x2183, '4xx32xxxxx'
Thu Sep 06 18:22:35 2012: <191>9439: Plan:ISDN, Type:National
Thu Sep 06 18:22:35 2012: <191>9440: Called Party Number i = 0xA1, '4xx34xxxxx'
Thu Sep 06 18:22:35 2012: <191>9441: Plan:ISDN, Type:National
Thu Sep 06 18:22:35 2012: <191>9442: Sep 7 00:22:34.646: ISDN Se0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8331
Thu Sep 06 18:22:35 2012: <191>9443: Channel ID i = 0xA9838E
Thu Sep 06 18:22:35 2012: <191>9444: Exclusive, Channel 14
Thu Sep 06 18:22:46 2012: <191>9445: Sep 7 00:22:44.755: ISDN Se0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x0331
Thu Sep 06 18:22:46 2012: <191>9446: Cause i = 0x82E6 - Recovery on timer expiry
Thu Sep 06 18:22:46 2012: <191>9447: Sep 7 00:22:44.771: ISDN Se0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8331
Thu Sep 06 18:24:40 2012: <191>9448: Sep 7 00:24:40.597: ISDN Se0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0332
Thu Sep 06 18:24:40 2012: <191>9449: Bearer Capability i = 0x8090A2
Thu Sep 06 18:24:40 2012: <191>9450: Standard = CCITT
Thu Sep 06 18:24:40 2012: <191>9451: Transfer Capability = Speech
Thu Sep 06 18:24:40 2012: <191>9452: Transfer Mode = Circuit
Thu Sep 06 18:24:40 2012: <191>9453: Transfer Rate = 64 kbit/s
Thu Sep 06 18:24:40 2012: <191>9454: Channel ID i = 0xA9838D
Thu Sep 06 18:24:40 2012: <191>9455: Exclusive, Channel 13
Thu Sep 06 18:24:40 2012: <191>9456: Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
Thu Sep 06 18:24:40 2012: <191>9457: Progress Ind i = 0x848B - Reserved value
Thu Sep 06 18:24:40 2012: <191>9458: Calling Party Number i = 0x2181, '4xx36xxxxx'
Thu Sep 06 18:24:40 2012: <191>9459: Plan:ISDN, Type:National
Thu Sep 06 18:24:40 2012: <191>9460: Called Party Number i = 0xA1, '4xx45xxxxxx'
Thu Sep 06 18:24:40 2012: <191>9461: Plan:ISDN, Type:National
Thu Sep 06 18:24:40 2012: <191>9462: Sep 7 00:24:40.649: ISDN Se0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8332
Thu Sep 06 18:24:40 2012: <191>9463: Channel ID i = 0xA9838D
Thu Sep 06 18:24:40 2012: <191>9464: Exclusive, Channel 13
Thu Sep 06 18:24:40 2012: <191>9465: Sep 7 00:24:40.673: ISDN Se0/0:23 Q931: TX -> PROGRESS pd = 8 callref = 0x8332
Thu Sep 06 18:24:40 2012: <191>9466: Sep 7 00:24:40.697: ISDN Se0/0:23 Q931: RX <- STATUS pd = 8 callref = 0x0332
Thu Sep 06 18:24:40 2012: <191>9467: Cause i = 0x82E0 - Mandatory information element missing
Thu Sep 06 18:24:40 2012: <191>9468: Call State i = 0x09
Thu Sep 06 18:24:40 2012: <191>9469: Sep 7 00:24:40.793: ISDN Se0/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x0332
Thu Sep 06 18:24:40 2012: <191>9470: Facility i = 0x9F8B0100A1080201010201008400
Thu Sep 06 18:24:40 2012: <191>9471: Sep 7 00:24:40.797: ISDN Se0/0:23 **ERROR**: Ux_BadMsg: Invalid Message for call state 7, call id 0x11E, call ref 0x8332, event 0x62
Thu Sep 06 18:24:41 2012: <191>9472: Sep 7 00:24:40.801: ISDN Se0/0:23 Q931: TX -> STATUS pd = 8 callref = 0x8332
Thu Sep 06 18:24:41 2012: <191>9473: Cause i = 0x80E262 - Message not compatible with call state or not implemented
Thu Sep 06 18:24:41 2012: <191>9474: Call State i = 0x07
Thanks all,
Ernest
09-10-2012 10:53 AM
Hi All,
I have made some progress but still having issue fo connect call behind the PBX. There is my process since the last time.
All outbound calls work fine. But i am getting Cause i = 0x80E6 - Recovery on timer expiry coming from the TELCO switch when calling number connected to the PBX, but test calls via FXS connect to GW work fine now . I have changed the ISDN timer T310 with no luck.
Part of the config:
no ip address
encapsulation hdlc
isdn timer T306 60000
isdn timer T310 120000
isdn supp-service name calling
isdn send-alerting
isdn sending-complete
isdn outgoing ie facility
isdn outgoing ie extended-facility
no isdn outgoing ie progress-indicator
isdn outgoing display-ie
isdn outgoing ie caller-number
isdn outgoing ie called-number
no cdp enable
Debug isdn q931
Fri Sep 07 17:24:50 2012: <191>10114: Sep 7 23:24:49.892: ISDN Se0/0:23 Q931: Applying typeplan for sw-type 0x3 is 0x2 0x1, Calling num 40x2xx97xx
Fri Sep 07 17:24:50 2012: <191>10115: Sep 7 23:24:49.900: ISDN Se0/0:23 Q931: Applying typeplan for sw-type 0x3 is 0x2 0x1, Called num 40x4xx64xx
Fri Sep 07 17:24:50 2012: <191>10116: Sep 7 23:24:49.900: ISDN Se0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0125
Fri Sep 07 17:24:50 2012: <191>10117: Sending Complete
Fri Sep 07 17:24:50 2012: <191>10118: Bearer Capability i = 0x8090A2
Fri Sep 07 17:24:50 2012: <191>10119: Standard = CCITT
Fri Sep 07 17:24:50 2012: <191>10120: Transfer Capability = Speech
Fri Sep 07 17:24:50 2012: <191>10121: Transfer Mode = Circuit
Fri Sep 07 17:24:50 2012: <191>10122: Transfer Rate = 64 kbit/s
Fri Sep 07 17:24:50 2012: <191>10123: Channel ID i = 0xA98396
Fri Sep 07 17:24:50 2012: <191>10124: Exclusive, Channel 22
Fri Sep 07 17:24:50 2012: <191>10125: Calling Party Number i = 0x2183, '40x2xx97xx'
Fri Sep 07 17:24:50 2012: <191>10126: Plan:ISDN, Type:National
Fri Sep 07 17:24:50 2012: <191>10127: Called Party Number i = 0xA1, '40x4xx64xx'
Fri Sep 07 17:24:50 2012: <191>10128: Plan:ISDN, Type:National
Fri Sep 07 17:24:50 2012: <191>10129: Sep 7 23:24:49.928: ISDN Se0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x03B2
Fri Sep 07 17:24:50 2012: <191>10130: Cause i = 0x82E6 - Recovery on timer expiry
Fri Sep 07 17:24:50 2012: <191>10131: Sep 7 23:24:49.940: ISDN Se0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x83B2
Fri Sep 07 17:24:50 2012: <191>10132: Sep 7 23:24:49.952: ISDN Se0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8125
Fri Sep 07 17:24:50 2012: <191>10133: Channel ID i = 0xA98396
Fri Sep 07 17:24:50 2012: <191>10134: Exclusive, Channel 22
Fri Sep 07 17:24:50 2012: <191>10135: Sep 7 23:24:50.004: ISDN Se0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x03B4
Fri Sep 07 17:24:50 2012: <191>10136: Bearer Capability i = 0x8090A2
Fri Sep 07 17:24:50 2012: <191>10137: Standard = CCITT
Fri Sep 07 17:24:50 2012: <191>10138: Transfer Capability = Speech
Fri Sep 07 17:24:50 2012: <191>10139: Transfer Mode = Circuit
Fri Sep 07 17:24:50 2012: <191>10140: Transfer Rate = 64 kbit/s
Fri Sep 07 17:24:50 2012: <191>10141: Channel ID i = 0xA9838E
Fri Sep 07 17:24:50 2012: <191>10142: Exclusive, Channel 14
Fri Sep 07 17:24:50 2012: <191>10143: Facility i = 0x9F8B0100A1080201010201008400
Fri Sep 07 17:24:50 2012: <191>10144: Calling Party Number i = 0x2183, '40x2xx97xx'
Fri Sep 07 17:24:50 2012: <191>10145: Plan:ISDN, Type:National
Fri Sep 07 17:24:50 2012: <191>10146: Called Party Number i = 0xA1, '40x4xx64xx'
Fri Sep 07 17:24:50 2012: <191>10147: Plan:ISDN, Type:National
Fri Sep 07 17:24:51 2012: <191>10148: Sep 7 23:24:50.161: ISDN Se0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x83B4
Fri Sep 07 17:24:51 2012: <191>10149: Channel ID i = 0xA9838E
Fri Sep 07 17:24:51 2012: <191>10150: Exclusive, Channel 14
Fri Sep 07 17:25:00 2012: <191>10151: Sep 7 23:24:59.937: ISDN Se0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x03B3
Fri Sep 07 17:25:00 2012: <191>10152: Cause i = 0x82E6 - Recovery on timer expiry
Fri Sep 07 17:25:00 2012: <191>10153: Sep 7 23:24:59.937: ISDN Se0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8124
Fri Sep 07 17:25:00 2012: <191>10154: Cause i = 0x8292 - No user responding
Fri Sep 07 17:25:00 2012: <191>10155: Progress Ind i = 0x8288 - In-band info or appropriate now available
Fri Sep 07 17:25:00 2012: <191>10156: Sep 7 23:24:59.957: ISDN Se0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x83B3
Fri Sep 07 17:25:00 2012: <191>10157: Sep 7 23:25:00.077: ISDN Se0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0125
Fri Sep 07 17:25:00 2012: <191>10158: Cause i = 0x80E6 - Recovery on timer expiry
Fri Sep 07 17:25:00 2012: <191>10159: Sep 7 23:25:00.113: ISDN Se0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8125
Fri Sep 07 17:25:01 2012: <191>10160: Sep 7 23:25:00.113: ISDN Se0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x03B4
Fri Sep 07 17:25:01 2012: <191>10161: Cause i = 0x80E6 - Recovery on timer expiry
Fri Sep 07 17:25:01 2012: <191>10162: Sep 7 23:25:00.141: ISDN Se0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0125 Fri Sep 07 17:24:50 2012: <191>10114: Sep 7 23:24:49.892: ISDN Se0/0:23 Q931: Applying typeplan for sw-type 0x3 is 0x2 0x1, Calling num 40x2xx97xx
Thanks all and really appreciate the help,
Ernest
09-10-2012 12:09 PM
When the telco sends a setup in, it is waiting for a setup ack, alerting or call proc. here there is no reply from the gateway and therefore you see the telco send a disconnect with the timer expiry. Changing T310 timer won't help here as that applies on outbound calls. You need to look at debug VoIP ccapi in out or debug ccsip to see why there is nothing being done by the gateway. The gateway should respond to the setup message which is not being done here which causes the telco to disconnect the call.
09-10-2012 12:45 PM
Thanks for the reply, and I greatly appreciate the help. Yes, you are right and as i mentioned above, alog phone on the GW connected via FXS port work fine. And in my initial setting, call went all the way to the PBX.. and I think they stop working after modifying the voip Dial-peer which forward calls to the PBX. I think the only modification done in that dial-peer was adding the transport protocol... I will remove that and test again, unfortunately i need to wait after business hours.
dial-peer voice 460 voip
preference 1
destination-pattern 40xxxxx4[0-9][0-9]$
progress_ind setup enable 3
progress_ind progress enable 8
voice-class codec 1
session target ipv4:10.204.x0.2xx:5060
session transport udp
dtmf-relay rtp-nte
no vad
Ernest
09-12-2012 01:39 AM
In session target, you only need to mention the IP Address and not port. Can you update that and test
09-12-2012 09:57 AM
Hi all,
I did update that, but there is no change(phone behind the PBX still CAN'T receive call from the PSTN).debug and new untested config. After some research, i have decided to add the progress-ind message in the inbound/outbound DP. Also, the cccapi debug shows the is full setup before the router send enother request setup to the TELCO switch...
tone ringback alert-no-PI
progress_ind alert enable 8
progress_ind connect enable 8
no digit-strip
direct-inward-dial
port 0/0:23
preference 1
destination-pattern 4xxxxxx[6-9][0-9]$
voice-class codec 1
session target ipv4:10x.2x.0.1xx
dtmf-relay rtp-nte
no vad
sh voice caLl STAtus
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0xCEC8 12E7 0x8445E064 0/0:23.19 40x4x0xx48x None 3004/460
0xCECA 12E8 0x8445E064 0/0:23.1 40x4x0xx48x None 3004/460
Debug
Tue Sep 11 18:05:05 2012: <191>43697: Calling Number=40xxx0xx78x(TON=Unknown, NPI=Unknown, Screening=Network, Presentation=Allowed),
Tue Sep 11 18:05:05 2012: <191>43698: Called Number=40x4x0xx48x(TON=Unknown, NPI=Unknown),
Tue Sep 11 18:05:05 2012: <191>43699: Redirect Number=, Display Info=40xxx0xx78x
Tue Sep 11 18:05:05 2012: <191>43700: Account Number=40xxx0xx78x, Final Destination Flag=TRUE,
Tue Sep 11 18:05:05 2012: <191>43701: Guid=EEF240B7-FBA3-11E1-97C1-E6FD50B8E5FF, Outgoing Dial-peer=460
Tue Sep 11 18:05:05 2012: <191>43702: Sep 12 00:02:10.552: //52715/EEF240B797C1/CCAPI/cc_api_display_ie_subfields:
Tue Sep 11 18:05:05 2012: <191>43703: ccCallSetupRequest:
Tue Sep 11 18:05:05 2012: <191>43704: cisco-username=40xxx0xx78x
Tue Sep 11 18:05:05 2012: <191>43705: ----- ccCallInfo IE subfields -----
Tue Sep 11 18:05:05 2012: <191>43706: cisco-ani=40xxx0xx78x
Tue Sep 11 18:05:05 2012: <191>43707: cisco-anitype=0
Tue Sep 11 18:05:05 2012: <191>43708: cisco-aniplan=0
Tue Sep 11 18:05:05 2012: <191>43709: cisco-anipi=0
Tue Sep 11 18:05:05 2012: <191>43710: cisco-anisi=3
Tue Sep 11 18:05:05 2012: <191>43711: dest=40x4x0xx48x
Tue Sep 11 18:05:05 2012: <191>43712: cisco-desttype=0
Tue Sep 11 18:05:05 2012: <191>43713: cisco-destplan=0
Tue Sep 11 18:05:05 2012: <191>43714: cisco-rdie=FFFFFFFF
Tue Sep 11 18:05:05 2012: <191>43715:
Tue Sep 11 18:05:05 2012: <191>43716: cisco-rdn=
Tue Sep 11 18:05:05 2012: <191>43717: cisco-rdntype=0
Tue Sep 11 18:05:05 2012: <191>43718: cisco-rdnplan=0
Tue Sep 11 18:05:05 2012: <191>43719: cisco-rdnpi=-1
Tue Sep 11 18:05:05 2012: <191>43720: cisco-rdnsi=-1
Tue Sep 11 18:05:05 2012: <191>43721: cisco-redirectreason=-1 fwd_final_type =0
Tue Sep 11 18:05:05 2012: <191>43722: final_redirectNumber =
Tue Sep 11 18:05:05 2012: <191>43723: hunt_group_timeout =0
Tue Sep 11 18:05:05 2012: <191>43724:
Tue Sep 11 18:05:05 2012: <191>43725: Sep 12 00:02:10.552: //52715/EEF240B797C1/CCAPI/ccIFCallSetupRequestPrivate:
Tue Sep 11 18:05:05 2012: <191>43726:
Tue Sep 11 18:05:05 2012: <191>43727: Interface=0x849AEE90, Interface Type=3, Destination=, Mode=0x0,
Tue Sep 11 18:05:05 2012: <191>43728: Call Params(Calling Number=40xxx0xx78x,(Calling Name=40xxx0xx78x)(TON=Unknown, NPI=Unknown, Screening=Network, Presentation=Allowed),
Tue Sep 11 18:05:05 2012: <191>43729: Called Number=40x4x0xx48x(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Tue Sep 11 18:05:05 2012: <191>43730: Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=460, Call Count On=FALSE,
Tue Sep 11 18:05:05 2012: <191>43731: Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Tue Sep 11 18:05:05 2012: <191>43732: Sep 12 00:02:10.556: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Tue Sep 11 18:05:05 2012: <191>43733:
Tue Sep 11 18:05:05 2012: <191>43734: Sep 12 00:02:10.556: :cc_get_feature_vsa malloc success
Tue Sep 11 18:05:05 2012: <191>43735: Sep 12 00:02:10.556: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Tue Sep 11 18:05:05 2012: <191>43736:
Tue Sep 11 18:05:05 2012: <191>43737: Sep 12 00:02:10.556: cc_get_feature_vsa count is 100
Tue Sep 11 18:05:05 2012: <191>43738: Sep 12 00:02:10.556: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Tue Sep 11 18:05:05 2012: <191>43739:
Tue Sep 11 18:05:05 2012: <191>43740: Sep 12 00:02:10.556: :FEATURE_VSA attributes are: feature_name:0,feature_time:2221066136,feature_id:42370
Tue Sep 11 18:05:05 2012: <191>43741: Sep 12 00:02:10.560: //52716/EEF240B797C1/CCAPI/ccIFCallSetupRequestPrivate:
Tue Sep 11 18:05:05 2012: <191>43742: SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Tue Sep 11 18:05:05 2012: <191>43743: Sep 12 00:02:10.560: //52716/EEF240B797C1/CCAPI/ccCallSetContext:
Tue Sep 11 18:05:05 2012: <191>43744: Context=0x84E8E8C0
Tue Sep 11 18:05:05 2012: <191>43745: Sep 12 00:02:10.560: //52715/EEF240B797C1/CCAPI/ccSaveDialpeerTag:
Tue Sep 11 18:05:05 2012: <191>43746: Outgoing Dial-peer=460
Tue Sep 11 18:05:05 2012: <191>43747: Sep 12 00:02:10.568: //52716/EEF240B797C1/CCAPI/cc_api_call_proceeding:
Tue Sep 11 18:05:05 2012: <191>43748:
Tue Sep 11 18:05:05 2012: <191>43749: Interface=0x849AEE90, Progress Indication=NULL(0)
Tue Sep 11 18:05:05 2012: <191>43750: Sep 12 00:02:10.600: //52618/EAA0EBE7969B/CCAPI/cc_api_call_disconnect_done:
Tue Sep 11 18:05:05 2012: <191>43751: Disposition=-11, Interface=0x849AEE90, Tag=0x0, Call Id=52618,
Tue Sep 11 18:05:05 2012: <191>43752: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Tue Sep 11 18:05:05 2012: <191>43753: Sep 12 00:02:10.600: //52618/EAA0EBE7969B/CCAPI/cc_api_call_disconnect_done:
Tue Sep 11 18:05:05 2012: <191>43754: Call Disconnect Event Sent
Tue Sep 11 18:05:05 2012: <191>43755: Sep 12 00:02:10.604: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Tue Sep 11 18:05:05 2012: <191>43756:
Tue Sep 11 18:05:05 2012: <191>43757: Sep 12 00:02:10.604: :cc_free_feature_vsa freeing 84629340
Tue Sep 11 18:05:05 2012: <191>43758: Sep 12 00:02:10.604: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Tue Sep 11 18:05:05 2012: <191>43759:
Tue Sep 11 18:05:05 2012: <191>43760: Sep 12 00:02:10.604: vsacount in free is 99
Tue Sep 11 18:05:05 2012: <191>43761: Sep 12 00:02:10.612: //52619/EAB47C3996A1/CCAPI/cc_api_call_disconnected:
Tue Sep 11 18:05:05 2012: <191>43762: Cause Value=16, Interface=0x849AEE90, Call Id=52619
Tue Sep 11 18:05:05 2012: <191>43763: Sep 12 00:02:10.612: //52619/EAB47C3996A1/CCAPI/cc_api_call_disconnected:
Tue Sep 11 18:05:05 2012: <191>43764: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Tue Sep 11 18:05:05 2012: <191>43765: Sep 12 00:02:10.624: //52617/EAA0EBE7969B/CCAPI/cc_api_call_disconnect_done:
Tue Sep 11 18:05:05 2012: <191>43766: Disposition=0, Interface=0x849AEE90, Tag=0x0, Call Id=52617,
Tue Sep 11 18:05:05 2012: <191>43767: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Tue Sep 11 18:05:05 2012: <191>43768: Sep 12 00:02:10.624: //52617/EAA0EBE7969B/CCAPI/cc_api_call_disconnect_done:
Tue Sep 11 18:05:05 2012: <191>43769: Call Disconnect Event Sent
Tue Sep 11 18:05:05 2012: <191>43770: Sep 12 00:02:10.624: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: Tue Sep 11 18:05:05 2012: <191>43697: Calling Number=40xxx0xx78x(TON=Unknown, NPI=Unknown, Screening=Network, Presentation=Allowed),
Thanks all
09-13-2012 05:47 PM
Hi all,
The previous changed(progress_ind) did not make any different(phone behind the pbx still can't receive call from pstn).... Any ideas where i should check or verify.... Below is the config, only the ip and number have been change
Any suggestion and help are greatly appreciate
isdn voice-call-failure 0
isdn logging
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
clid network-provided
sip
voice class codec 1
codec preference 4 g726r24
archive
log config
hidekeys
controller T1 0/0
framing esf
linecode b8zs
ip ssh version 1
interface FastEthernet0/0
ip address 1X.1xx.0.2xx 255.255.255.0
speed auto
no cdp enable
no ip address
encapsulation hdlc
isdn send-alerting
isdn outgoing ie display
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
no ip http server
no ip http secure-server
control-plane
voice-port 0/0:23
echo-cancel coverage 24
timeouts interdigit 3
voice-port 1/0
voice-port 1/1
no digit-strip
direct-inward-dial
port 0/0:23
dial-peer voice 3030 voip
description -- SEND CALLS TO pbx
preference 1
destination-pattern 4XXXXXX[3-5][0-9]$
voice-class codec 1
session target ipv4:X.X.X.X
dtmf-relay rtp-nte
no vad
dial-peer voice 34516453 voip
preference 1
destination-pattern 4XXXXXXX[3-9]$
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
destination-pattern 405XXXXX[6-9][0-9]$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 03 pots
incoming called-number 4XXXX[3-5][0-9]
direct-inward-dial
dial-peer voice 3004 pots
incoming called-number 4XXXXXX[6-9][0-9]
direct-inward-dial
dial-peer voice 3005 pots
incoming called-number 4xxxxxxxx.
direct-inward-dial
dial-peer voice 3006 pots
incoming called-number xxxxxxxxx
direct-inward-dial
dial-peer voice 3007 pots
direct-inward-dial
dial-peer voice 3008 pots
voice cut-through alert
port 1/1
09-14-2012 12:20 AM
Progess IE message works in H323 not SIP. You VoIP dial-peers are using SIP protocol. You are missing your SIP source IP.
voice service voip
sip
bind all source-interface
"please rate useful posts"
09-14-2012 08:34 AM
I doubt that is the case here as debug ccsip show registration OK... But it does also send ****Deleting from UAS Request table. Please the debug below..
Fri Sep 14 08:42:09 2012: <191>72211: Sent:
Fri Sep 14 08:42:09 2012: <191>72212: SIP/2.0 200 OK
Fri Sep 14 08:42:09 2012: <191>72213: Via: SIP/2.0/UDP 1x.1x.0.xxx:5060;branch=z9hG4bK25f4afeb;rport
Fri Sep 14 08:42:09 2012: <191>72214: From: "unknown"
Fri Sep 14 08:42:09 2012: <191>72215: To: <1X.1X.0.2XX>;tag=32741709-15D81X.1X.0.2XX>
Fri Sep 14 08:42:09 2012: <191>72216: Date: Fri, 14 Sep 2012 14:42:09 GMT
Fri Sep 14 08:42:09 2012: <191>72217: Call-ID: 4202eaee09254c236e5f30bc1be7b300@1x.1x.0.xxx
Fri Sep 14 08:42:09 2012: <191>72218: Server: Cisco-SIPGateway/IOS-12.x
Fri Sep 14 08:42:09 2012: <191>72219: CSeq: 102 OPTIONS
Fri Sep 14 08:42:09 2012: <191>72220: Supported: 100rel,resource-priority,replaces
Fri Sep 14 08:42:09 2012: <191>72221: Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Fri Sep 14 08:42:09 2012: <191>72222: Allow-Events: telephone-eve
Fri Sep 14 08:42:10 2012: <191>72223: nt
Fri Sep 14 08:42:10 2012: <191>72224: Accept: application/sdp
Fri Sep 14 08:42:10 2012: <191>72225: Content-Type: application/sdp
Fri Sep 14 08:42:10 2012: <191>72226: Content-Length: 165
Fri Sep 14 08:42:10 2012: <191>72227:
Fri Sep 14 08:42:10 2012: <191>72228: v=0
Fri Sep 14 08:42:10 2012: <191>72229: o=CiscoSystemsSIP-GW-UserAgent 7745 5866 IN IP4 1x.1x.0.2xx(Voice-GW)
Fri Sep 14 08:42:10 2012: <191>72230: s=SIP Call
Fri Sep 14 08:42:10 2012: <191>72231: c=IN IP4 1x.1x.0.2xx(Voice-GW)
Fri Sep 14 08:42:10 2012: <191>72232: t=0 0
Fri Sep 14 08:42:10 2012: <191>72233: m=audio 0 RTP/AVP 18 0 8 4 2 15
Fri Sep 14 08:42:10 2012: <191>72234: c=IN IP4 1x.1x.0.2xx(Voice-GW)
Fri Sep 14 08:42:10 2012: <191>72235:
Fri Sep 14 08:42:41 2012: <191>72236: Sep 14 14:42:41.242: //64522/3243EFA48442/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id FC0A
Fri Sep 14 08:42:41 2012: <191>72237: Sep 14 14:42:41.242: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[63763] removed.
Fri Sep 14 08:42:41 2012: <191>72238: Sep 14 14:42:41.242: //64522/3243EFA48442/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
Fri Sep 14 08:42:41 2012: <191>72239: Sep 14 14:42:41.242: //64522/3243EFA48442/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x8526FC8C key=4202eaee09254c236e5f30bc1be7b300@1x.1x.0.xxx
Fri Sep 14 08:42:41 2012: <191>72240: Sep 14 14:42:41.242: //64522/3243EFA48442/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
Fri Sep 14 08:42:42 2012: <191>72241: Sep 14 14:42:41.242: //64522/3243EFA48442/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Fri Sep 14 08:42:42 2012: <191>72242: Sep 14 14:42:41.246: //64522/3243EFA48442/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 8526FC8C
Fri Sep 14 08:43:09 2012: <191>72243: Sep 14 14:43:09.248: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 1x.1x.0.xxx:5060
Fri Sep 14 08:43:09 2012: <191>72244: Sep 14 14:43:09.248: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Fri Sep 14 08:43:09 2012: <191>72245: Sep 14 14:43:09.248: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
Fri Sep 14 08:43:09 2012: <191>72246: Sep 14 14:43:09.252: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Fri Sep 14 08:43:09 2012: <191>72247: Received:
Fri Sep 14 08:43:09 2012: <191>72248: OPTIONS sip:1x.1x.0.2xx(Voice-GW);user=phone SIP/2.0
Fri Sep 14 08:43:09 2012: <191>72249: Via: SIP/2.0/UDP 1x.1x.0.xxx:5060;branch=z9hG4bK34bbcfe2;rport
Fri Sep 14 08:43:09 2012: <191>72250: From: "unknown"
Fri Sep 14 08:43:09 2012: <191>72251: To: <1X.1X.0.2XX>1X.1X.0.2XX>
Fri Sep 14 08:43:09 2012: <191>72252: Contact:
Fri Sep 14 08:43:09 2012: <191>72253: Call-ID: 02fe4bff71b8785c345480974721d788@1x.1x.0.xxx
Fri Sep 14 08:43:09 2012: <191>72254: CSeq: 102 OPTIONS
Fri Sep 14 08:43:09 2012: <191>72255: User-Agent: Asterisk PBX (digium)
Fri Sep 14 08:43:09 2012: <191>72256: Max-Forwards: 70
Fri Sep 14 08:43:09 2012: <191>72257: Date: Fri, 14 Sep 2012 14:43:17 GMT
Fri Sep 14 08:43:09 2012: <191>72258: Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Fri Sep 14 08:43:09 2012: <191>72259: Supported: replaces
Fri Sep 14 08:43:09 2012: <191>72260: Content-Length: 0
Fri Sep 14 08:43:09 2012: <191>72261:
Fri Sep 14 08:43:09 2012: <191>72262:
09-17-2012 12:38 PM
Hi ALL,
I am still fighting with that issue, but it seems i getting cloer to resolve it. Recent wireshark shows that CANCEL request comes from the H323 GW. Please see below
