FXO port issue
Dear all,
Am using cisco 2921 CME 8.6 with ios version c2900-universalk9-mz.SPA.151-4.M4.bin..
Also am using a dedicated one fxo port for a specific user to send and receive calls,, the user always faces busy tone when initiate outgoing call, the fxo port doesnt disconnect from the previous call.
voice-port 0/3/2
supervisory disconnect dualtone mid-call
no battery-reversal
cptone SA
timeouts interdigit 3
timeouts call-disconnect 1
timeouts wait-release 1
connection plar opx immediate 4015
impedance complex2
caller-id enable
Any Idea to solve the issue, please???
#sh voice port 0/3/2
Foreign Exchange Office 0/3/2 Slot is 0, Sub-unit is 3, Port is 2
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is plar opx
Connection Number is 4015
Initial Time Out is set to 15 s
Interdigit Time Out is set to 3 s
Call Disconnect Time Out is set to 1 s
Power Denial Disconnect Time Out is set to 1000 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 1 s
Companding Type is u-law
Region Tone is set for SA
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to complex2 Ohm
Station name None, Station number None
Caller ID Info Follows:
Standard BELLCORE
Caller ID is received after 1 ring(s)
Translation profile (Incoming):
Translation profile (Outgoing):
lpcor (Incoming):
lpcor (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is disabled
Number Of Rings is set to 1
Supervisory Disconnect is dualtone mid-call
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Out Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 65 percent
GuardOut timer is 2000 ms
Minimum ring duration timer is 125 ms
Hookflash-in Timing is set to 600 ms
Hookflash-out Timing is set to 400 ms
Supervisory Disconnect Timing (loopStart only) is set to 350 ms
OPX Ring Wait Timing is set to 6000 ms
Secondary dialtone is disabled
23 Replies 23
Being this my profession for some 15 years, I do understand your problem.
What I'm trying to have you understand, is that when the IP phone hangs up, the FXO port MUST hang up as well, so there is something strange. Unless you are talking about a call that as never been answered, Auto Attendant, Transferred fxo to fxo, etc.
For the other question, yes. That is called paging.
Hi again Mr. Paolo, and thanks for your time.
No, am not talking about a call never been answered, however what i did is unplug and plug again the fxo cards from the router, remove unused E1 card that was installed in the router, and scince yesterday i receive no calls. the next step is updating the IOS,.
Yes i know its paging, but instead of listening on ip phones, i wanted via speakers, is it supported? how to connect speakers to CME router? and what type of speaker is you don`t mind.
thanks again Paolo.
regards,
Strange issue occur Mr. Paolo, the voice ports seem to be ok, in on-hook status  and incoming calls are fine, the strange issue is outgoing calls can`t  be initiated despite the dial-peer are configured. this issue happens to  me suddenly before changing any thing. As soon i dial the first digit  after dialing 9, i receive a fast busy tone, like below as soon i dial 7 i receive a fast busy tone from an ip phone with no restriction...
dial-peer voice 2002 pots
trunkgroup 2
corlist outgoing CDMA
destination-pattern 977.......
forward-digits 9
voice-port 0/2/0
trunk-group 2
no battery-reversal
cptone SA
connection plar opx immediate 4446
impedance complex2
caller-id enable
I  restart the router, boot from another ios, remove and configure the  dial-peers, shut and unshut the voice port, nothing solve the issue. it  seems it doesn`t recognize outside digits,,, local calls are working  fine..
Any ideas to solve the issue please...
Based on your symtoms, both FXO and IP Phone call leg might be hung up!
That why I need your "show voice call status" after the call finished and the guy hangs up his ip phone!
Yes Mr. Lan,
and till now it works fine,,
i`ll update you with new things.
thanks.
Hi again Lan,
Strange issue occur, the voice ports seem to be ok, in on-hook status and incoming calls are fine, the strange issue is outgoing calls can`t be initiated despite the dial-peer are configured. this issue happens to me suddenly before changing any thing. As soon i dial the first digit after dialing 9, i receive a fast busy tone, like below as soon i dial 7 i receive a fast busy tone from an ip phone with no restriction...
trunkgroup 2
forward-digits 9
voice-port 0/2/0
trunk-group 2
no battery-reversal
cptone SA
impedance complex2
caller-id enable
the below is info you requested while the ports are hanging:
VoiceGW#sh voice call status
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0x11       121D 0x2B326244 0/2/1            No DSP  7444624261 None     0/1015
0x17       121D 0x2B334ADC 0/3/3            No DSP *7444624261 None      1015/0
1 active call found
Enter configuration commands, one per line.  End with CNTL/Z.
VoiceGW(config)#exdo sh voice port summ
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/1/0           --  fxs-ls      up    dorm on-hook  idle     y
0/1/1           --  fxs-ls      up    dorm on-hook  idle     y
0/1/2           --  fxs-ls      up    dorm on-hook  idle     y
0/1/3           --  fxs-ls      up    dorm on-hook  idle     y
0/2/0           --  fxo-ls      up    dorm idle     on-hook  y
0/2/1           --  fxo-ls      up    up   idle     off-hook y
0/2/2           --  fxo-ls      up    dorm idle     on-hook  y
0/2/3           --  fxo-ls      up    dorm idle     on-hook  y
0/3/0           --  fxo-ls      up    dorm idle     on-hook  y
0/3/1           --  fxo-ls      up    dorm idle     on-hook  y
0/3/2           --  fxo-ls      up    dorm idle     on-hook  y
0/3/3           --  fxo-ls      up    up   idle     off-hook y
50/0/1          1      efxs     up    up   on-hook  idle     y
50/0/1          2      efxs     up    up   on-hook  idle     y
VoiceGW(config-voiceport)#no sh
Jul 31 12:13:57.923: htsp_process_event: [0/2/1, FXOLS_CONNECT, E_HTSP_IF_OOS]htspm_mgt_statehtspm_disc_ind
Jul 31 12:13:57.923: htsp_timer_stop
Jul 31 12:13:57.923: htsp_timer_stop2
Jul 31 12:13:57.923: htsp_timer - 1000 msec
Jul 31 12:13:57.923: htsp_process_event: [0/2/1, S_DOWN, E_HTSP_RELEASE_REQ]act_disc_conf
Jul 31 12:13:57.923: htsp_process_event: [0/3/3, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
QNB_VoiceGW(config-voiceport)#Jul 31 12:13:57.923: htsp_timer_stop3
Jul 31 12:13:57.923: [0/3/3] set signal state = 0x4 timestamp = 0
Jul 31 12:13:57.923: htsp_timer - 2000 msec
Jul 31 12:13:58.923: htsp_process_event: [0/2/1, S_DOWN, E_HTSP_EVENT_TIMER]htspm_disc_conf
Jul 31 12:13:58.923: htsp_timer_stop
Jul 31 12:13:58.923: htsp_timer_stop2
Jul 31 12:13:58.923: htsp_process_event: [0/2/1, S_DOWN, E_HTSP_IF_OOS_CONF]
Jul 31 12:13:58.923: htsp_timer_stop3
Jul 31 12:13:58.923: htsp_timer_stop_mlpp
Jul 31 12:13:58.923: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/1, changed state to Administrative Shutdown
Jul 31 12:13:58.923: htsp_process_event: [0/2/1, S_DOWN, E_DSP_INTERFACE_INFO]
Jul 31 12:13:59.339: htsp_process_event: [0/2/1, S_DOWN, E_HTSP_IF_INSERVICE]
Jul 31 12:13:59.343: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/1, changed state to up
Jul 31 12:13:59.343: Foreign Exchange Office 0/2/1 rx_signal_map:
F F F F
5 F F F
F F F F
F F F F
Jul 31 12:13:59.343: [0/2/1] set signal state = 0xC timestamp = 0
Jul 31 12:13:59.343: Foreign Exchange Office 0/2/1 tx_signal_map:
0 4 4 4
4 4 6 4
C C C C
C C C C
Jul 31 12:13:59.343: htsp_process_event: [0/2/1, S_OPEN_PEND, E_HTSP_GO_UP]
Jul 31 12:13:59.455: htsp_process_event: [0/2/1, FXOLS_NULL, E_HTSP_INIT]fxols_null_init
Jul 31 12:13:59.455: [0/2/1] set signal state = 0xC timestamp = 0
Jul 31 12:13:59.455: htsp_process_event: [0/2/1, FXOLS_INIT, E_HTSP_INSERVE]fxols_init_inserve
Jul 31 12:13:59.455: [0/2/1] set signal state = 0x4 timestamp = 0
Jul 31 12:13:59.455: htsp_process_event: [0/2/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
Jul 31 12:13:59.923: htsp_process_event: [0/3/3, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Jul 31 12:13:59.927: htsp_process_event: [0/3/3, FXOLS_ONHOOK, E_DSP_SIG_0100]
Could you please put entire Router configure here??
And log of "show dial-peer voice sum"
Based on your information :
The incoming call arrived in port 0/2/1 ( inbound call leg) the it 's routed out port 0/3/3 (outbound call leg)
And according to your info, it stuck at that point ---> this is not relate to IP Phone failure of making call.
I wonder if the incoming call was routed to an IP Phone (or vise versa), how the status would be after the call finished.
saif musa
Level 4
Level 4
Try to contact your PSTN administration to chick signaling between your FXO card and them. I think you need to identify in voice ports whither the signaling is loopstart or ground start.
Hope that helps
Sent from Cisco Technical Support Android App
jamalludin
Hi Mohammed
i have same issue, can you tell me how to fix this ?
user can make a call because line is busy. for temporary solution i was shut and no shut the voice-port.
SHIELD#sh voice call status
CallID     CID  ccVdb      Port             DSP/Ch  Called #   Codec    Dial-peers
0x532B     18CD 0x493815A0 0/2/0            0/1:2  *7675030452 g711ulaw  0/1000
0x532D     18D3 0x493835B0 0/2/1            0/1:3  *7675030452 g711ulaw  0/2000
0x5338     18E5 0x49385C88 0/3/0            0/1:1  *7675030452 g711ulaw  0/3000
3 active calls found
can you tell me how to fix this isue ?
